Author Topic: Connection Time Out issues  (Read 24488 times)
Re: Connection Time Out issues
« Reply #45 on: August 09, 2023, 18:19:31 »
We just renewed our SSL certificate, that might have a bearing here.
I recommend clearing the browser cache for any NG cookie. You will need to log in again.
Running the command ipconfig /flushdns (Windows) usually helps as well.
« Reply #46 on: August 09, 2023, 21:56:58 »
To quickly dump the cache on most browsers try (clicking an open area of your browser, i.e. not with the focus on a dialog box)...
(Command/Control) + Shift + (Delete/Backspace)
Take care to only delete or clear the cache and not your passwords or other items you might wish to retain.
Hope this works for you
This probably does not work with Safari.
[Maybe dump cookies? Probably not all.]
« Reply #47 on: August 29, 2023, 09:04:10 »
Today. Very slow connection, with time-outs.
« Reply #48 on: September 04, 2023, 10:45:45 »
09:45 BST very slow responses
Initially,  took an age to load
Then connection timed out
It eventually reloaded.
« Reply #49 on: October 11, 2023, 09:32:17 »
We experienced a hiccup leading to connection time-outs this morning, which apparently was solved after I rebooted the server.
« Reply #50 on: October 23, 2023, 14:10:58 »
Do note NG will move to another hosting provider by 25 October, 2023, and we hope this move also squashes the annoying connection time-outs and response slowness we have seen in the last months.
NG will be offline from 25 Oct. and hopefully accessible again at latest 1 November. However, we enter unchartered (to us) waters, so be prepared for unexpected contingencies.
« Reply #51 on: October 23, 2023, 14:13:14 »
We are all crossing our fingers ;D  Thank you!
« Reply #52 on: October 23, 2023, 15:20:25 »
Yes, good luck.  Such operational changes can be as they say "character building".   ;D
Ian Watson
« Reply #53 on: October 23, 2023, 17:26:04 »
Birna already has a lot of character. Is it possible to have too much?  ;D
Thank you for all the work, Birna, and best of luck with the migration.
« Reply #54 on: October 23, 2023, 17:40:33 »
Good luck with the move!  I appreciate any efforts of the administrators to keep NG going.
« Reply #55 on: October 23, 2023, 21:11:26 »
+1. Must agree  :)
« Reply #56 on: October 23, 2023, 22:10:33 »
Crossing fingers and wishing you serene nights during the move.
« Reply #57 on: October 31, 2023, 00:13:52 »
The move is finalised, forum (with some caveats regarding Gallery) is working, DNS is pointed to the new domain.
I call it a day and hit the sack.
« Reply #58 on: October 31, 2023, 02:17:52 »
I could log in a while ago, but the log-in time was untimely out.
Since then, I haven't been able to log in for a while, but now I can.  Hope everything is going as planned!
« Reply #59 on: October 31, 2023, 02:25:07 »
My forum profile seems to have remained intact.  Only the "Look and Layout" has been reverted to the default setting.
