Author Topic: Connection Time Out issues  (Read 28819 times)
Lars Hansen
  • Zealand, Denmark
« on: September 15, 2022, 17:21:16 »
I'm having "The Connection has timed out" issues and cannot acces the site from my internet connection - anyone  else experiencing this? Has the site network settings been updated recently?
Might be a local issue - this  was sent via my mobile connection that works ok.
Re: Connection Time Out issues
« Reply #1 on: September 15, 2022, 19:41:13 »
Same issue here. Hope it will be resolved quickly
« Reply #2 on: September 16, 2022, 04:02:09 »
Sorry about that.  I have no problem in accessing from Japan.
Maybe there is some problem with the network in Denmark?
« Reply #3 on: September 16, 2022, 10:41:23 »
Birna will do a reboot of the web server as soon as possible  :)
Bill De Jager
« Reply #4 on: September 16, 2022, 17:52:57 »
Thank you.  I had no access from the U.S. yesterday morning.  Site loads well today.
« Reply #5 on: September 16, 2022, 20:06:28 »
Have had problems but it works smoothly now in Spain too.
« Reply #6 on: September 16, 2022, 20:22:24 »
Yes, all seems to be good again ;)
Lars Hansen
  • Zealand, Denmark
« Reply #7 on: September 16, 2022, 23:20:07 »
.. and fine response times as well from my part of the world :)
« Reply #8 on: September 17, 2022, 10:47:12 »
Still a bit slow here ( but maybe it's my connection) after almost 2 days of time out.
« Reply #9 on: September 17, 2022, 14:17:13 »
A dedicated kick in the virtual behind of NG obviously helped solve the issue :)
« Reply #10 on: September 19, 2022, 12:49:26 »
Thanks Eric & Birna
I'd been getting "failed to connect in allotted time" types of issues for several weeks in early September.
Brute
  • Podunk USA
« Reply #11 on: September 19, 2022, 17:38:36 »
Having  the same problem  here in  Oregon  USA.
Ken Smith
« Reply #12 on: September 19, 2022, 18:32:40 »
Thanks Eric & Birna
After a week or so of behaving better, I got a timeout error again just now.
In addition, when I looked at the Shape Echo thread, the image in one of the posts failed to display.
It was only 250Kb.
As a precaution I checked my Internet connection and it seems that wasn't the problem - see below
Is another kick (or some gentler but more deep reaching surgery) needed?
« Reply #13 on: September 20, 2022, 02:47:09 »
Failing to display images is the early symptom - it will miss the last images to displayed on a page. I see it before the site finally becomes unavailable. Yes, it just happened again after having been better for a few days.
Bob Foster
« Reply #14 on: September 22, 2022, 15:56:10 »
Failure to load nikongear.net/revival at 13:42 UCT. Timeout issue: I've doubled the time that my copy of Firefox allows before issuing the related notice.
Perhaps this is, at least from my end, DNS related. On old trace utility showed two flaws in the attempt at connection when using nikongear.net/revival, using the ip the connection took an entirely different and successful path.
https://162.241.212.49/revival/index.php?action=login worked.
An attempt to use nikongear.net/revival worked at 13:54 UCT. Strange!
