Author Topic: Connection Time Out issues  (Read 31983 times)
Re: Connection Time Out issues
« Reply #15 on: September 23, 2022, 11:48:00 »
If you encounter DNS issues, a trick is to put nikongear.net into your HOSTS file with the IP-address 162.241.212.49 :) that will ensure the browser finds the site immediately without use of DNS.
Add the following line to the HOSTS file
162.241.212.49 nikongear.net
and remember to save the file without any extension.
On Windows systems, the file is found at <systemdrive>\windows\system32\drivers\etc; for other OS, consult manuals or search on the 'net for the information. Some systems use the name in lower case.
« Reply #16 on: September 23, 2022, 22:57:46 »
Is there an equivalent on non-windows devices Birna?
I'm getting the issues on my main day to day device, an Android tablet (as well as my Win 10 PC)
« Reply #17 on: September 23, 2022, 23:07:48 »
On most Linux systems, it is /etc/hosts. Not familiar with Apple or Android. However, do a quick 'net search and you'll find the required recipes.
« Reply #18 on: May 17, 2023, 11:16:18 »
Experiencing issues today connection drop-offs.
« Reply #19 on: May 17, 2023, 11:32:22 »
Same here, very slow response time.
« Reply #20 on: May 17, 2023, 12:48:50 »
Time-outs come and go. Tracert indicates the issue is not in Europe.
Re: Connection Time Out issues - solved
« Reply #21 on: May 17, 2023, 20:32:06 »
Apparently the time-out issue is solved now? Response is OK and tracert does not indicate any blocked connections. Might be a central network hub on the US side that had issues.
« Reply #22 on: May 18, 2023, 10:12:10 »
It's solved indeed. No problem anymore.
« Reply #23 on: May 19, 2023, 12:40:08 »
After the time out issue had once been solved, it recurred several hours ago, and that was even worse: I couldn't access the site at all.
Now it is normal again,,,
« Reply #24 on: May 19, 2023, 12:41:37 »
We saw a short period of site outage this morning, but it quickly resolved. Our server went offline and was unreachable through ping or tracert. Will go through the server logs later today to see if something is reported.
 I have sent a support ticket to our hosting providers to complain about the last week's instability and am waiting for a response.
Added: our server was rebooted by hosting maintenance around 12:05 today UTC+2. So we either experienced a hung process or there was a local network error.
« Reply #25 on: May 19, 2023, 20:56:53 »
The site was completely down for me the whole yesterday (Alaska time).
Snoogly
  • Flipping the bird
« Reply #26 on: May 20, 2023, 05:55:57 »
Currently in Japan the site loads, but a noticeable delay.
« Reply #27 on: May 24, 2023, 14:35:40 »
Apparently, the site loads slower again (from Japan)...
« Reply #28 on: May 24, 2023, 14:37:35 »
...and now loads normally.   :o :o :o
« Reply #29 on: May 24, 2023, 14:40:11 »
Site time out issues and genral slowness here in Denmark too,,,
