Author Topic: April 2021  (Read 44677 times)
Re: April 2021
« Reply #270 on: April 29, 2021, 17:07:44 »
Night broken glass, Córdoba
  Z6, 50mm 1.8s
Re: April 2021
« Reply #271 on: April 29, 2021, 22:53:23 »
April 29
crossing the bridge
Z6, 105mm f/1.4
Perfect shot and most adequate processing. Tells a story. Somehow this most recent gear seems able to emulate the older one :)
Re: April 2021
« Reply #272 on: April 29, 2021, 23:59:42 »
Fons and Paco, nice reminders of Van Gogh and Duchamp respectively.
Bill De Jager
Re: April 2021
« Reply #273 on: April 30, 2021, 04:25:59 »
Vetch in bloom
by Bill de Jager, on Flickr
I followed Birna's advice on another thread and went out to do a little shooting.  Our Mediterranean landscape in California is transitioning from the end of the wet season to the beginning of the dry season, where the grasses and flowers are largely dormant in the form of seeds, roots, and the like.  This year the wet season delivered only a fraction of the usual moisture so there will likely be some bad fires later in the year. Still, there are flowers to be found.
Tom Hook
  • Tom
Re: April 2021
« Reply #274 on: April 30, 2021, 05:31:21 »
A mop on the flagstones
Re: April 2021
« Reply #275 on: April 30, 2021, 11:37:44 »
Thank you Akira.
  Spring behavior.
  D5, rodenstock 95mm 1.4 (purchased here from some north european fierce member  :) )
Re: April 2021
« Reply #276 on: April 30, 2021, 11:53:34 »
Alder leaf beetle
"Paco, coincidentally a beetle in focus"
Z6, 28mm f/1.4e
Re: April 2021
« Reply #277 on: April 30, 2021, 12:03:50 »
Thanks, this is the colour version.
Re: April 2021
« Reply #278 on: April 30, 2021, 13:29:55 »
Despite my transition, I'm still capable of indulging my previous nerdy instincts. This time just showing a test shot with the 38mm f/2.8 Olympus OM macro lens (modified to Nikon F mount) equipped with a modified Laowa LED ring light, the package deployed on one of my V1 cameras through the Erik-enhanced FT-1 adapter. I could, thanks to the quite bright LED light, easily shoot at pretty fast speeds 1/125-1/200 sec with a hand-held camera. All this in preparation for the upcoming field season, which looks to be very busy indeed. Probably will use a Z camera instead of the little V1 for any serious macro work in the field, though. The OM 38/2.8 itself is all metal, very robust and gives good image quality so is ideal for the hazards of field investigations on aquatic plants. The Laowa LED ring light is designed for their 25mm f/2.8 'ultra-macro' lens, which I use extensively, but constrained to studio photography. With a suitable ring from my odds-and-ends boxes and some Epoxy glue, the ring light now is seated on the Olympus lens. I purchased another Laowa ring light for use on the 25mm lens as these items are quite inexpensive. In field I feed power to the ring light from a Power Bank, in the studio any 5V USB source will do.
Dot Your I's
mxbianco
Re: April 2021
« Reply #279 on: April 30, 2021, 21:05:20 »
This morning's setting Moon
...above and behind the San Luca Sanctuary
Nikon DF
Ciao from Massimo
Re: April 2021
« Reply #280 on: April 30, 2021, 21:11:22 »
Ethereal and stunning result Massimo
A superb melange of sawtooth silhouette skyline and lacy moon/clouds
Re: April 2021
« Reply #281 on: April 30, 2021, 21:11:36 »
Beautiful scenery with moon, Massimo.
  It looks like it was a bug´s day, Fons  :)
   Some lowkey carpobrotus edulis (I think, "uña de gato/ cat´s claw" is called here), it is considered invasive in Spain and very common in my hometown, close to the water, south Spain, mild weather.
  D5, 70-200 2.8 fl @2.8
mxbianco
Re: April 2021
« Reply #282 on: April 30, 2021, 21:28:49 »
Thanks Paco and Colin!
The Carpobrotus is called Fico degli Ottentotti in Italy. Very common and invasive here too, but flowers (multicolored) are lovely!
Ciao from Massimo
Re: April 2021
« Reply #283 on: April 30, 2021, 21:34:02 »
Earlier this month:  an accident in the street, resulting in the loss of 3 vehicles.  Luckily no personal injuries.
D4s  28/1.4E
mxbianco
Re: April 2021
« Reply #284 on: April 30, 2021, 23:27:38 »
Springtime: not only bugs
Nikon 1V3 + FT1 + 200-500mm f/5.6E @500mm
Ciao from Massimo
