Author Topic: Would you pay 1000 for this Nikkor set??  (Read 6538 times)
Danulon
Re: Would you pay 1000 for this Nikkor set??
« Reply #15 on: December 29, 2020, 20:49:28 »
Look here, most on my site is done with that special quartz/fluorite UV lens http://uvir.eu
Basically it is about this, making the (for us) invisible UV (300-400nm), visible (as we see only 400-750nm)!
Danke für die Information, Klaus!So this lens actually lets you take UV images?I assumed that a sensor modification was needed for UV images...
Guenther Something
« Reply #16 on: December 29, 2020, 21:05:59 »
Most modern cameras need to be modified in order to capture a UV image. Plus, having a UV-capable lens in addition makes the challenges easier to tackle.
I own several UV-Nikkors myself and in fact, bought one of them from Klaus many years ago.
Much more about UV is to be found at our sister site, https://www.ultravioletphotography.com/content/
« Reply #17 on: December 29, 2020, 22:43:58 »
Most welcome! Yes, cameras need to have their sensor filter replaced with an UV capable window, ideally fused silica, which I prefer. A lot of
companies offer that now; most of them listed on my site and indeed also at ultravioletphotography.com, as Birna has already mentioned.
MILLIREHM
  • Vienna, Austria
« Reply #18 on: December 30, 2020, 00:05:51 »
What a great deal Klaus - you have got three good lenses (that look OK as far as i can see) plus the elusive 105 mm f/4,5 UV-Micro-Nikkor for free! congratulations!
Wolfgang Rehm
« Reply #19 on: December 30, 2020, 10:49:49 »
Danke Wolfgang! Indeed a very lucky catch!
« Reply #20 on: January 01, 2021, 18:48:12 »
Nice find! Congratulation
« Reply #21 on: January 02, 2021, 12:13:43 »
Thnks Erik!
Happy New Year (to all)!!
« Reply #22 on: January 02, 2021, 19:03:35 »
Thnks Erik!
what did you pay in the end?
« Reply #23 on: January 02, 2021, 21:53:40 »
« Reply #24 on: January 03, 2021, 12:19:59 »
There is a brand new UV-Nikkor available here......and the British £ is relative low.....
https://shop.graysofwestminster.co.uk/product/105mm-f-4-5-uv-nikkor-ais/
.....there seems to be more in the box that just the lens......
« Reply #25 on: January 03, 2021, 12:40:45 »
I have two UR-2 50x50mm filter holder lying around.  It is handy but its rear thread is weird 60mm P0.5mm which makes its use limited on AF-1.
mxbianco
« Reply #26 on: January 03, 2021, 13:30:34 »
With such a lowball figure, in Italy we would say
Hai avuto una bella botta di culo !!!
(fig. You had a super strike on your ars**hole)
While I was looking down the ad photos, I was adding up...
50mm/1.2 300€
μNikkor 55mm/2.8 +75€ (so far 375€)
105/2.5 +75€ (so far 450€)
μNikkor 105/4.5 +150€ ... wait a minute!!! ... 4.5? UV Nikkor!!!
Enjoy!
Ciao da Massimo
« Reply #27 on: January 03, 2021, 16:49:20 »
For long I don't use them anymore, XUME MANFROTTO magnetic filter holder rings are so much better!
F2F3F6
« Reply #28 on: January 03, 2021, 20:27:53 »
Congratulations for this good (and very cheap) buy, Dr Klaus ! Ein Volltreffer, wie Massimo es sagt ! How many of this special lenses (UV Nikkor or other UVs from Pentax - Takumar UV -, Zeiss or other makers) do you have ?
MILLIREHM
  • Vienna, Austria
« Reply #29 on: January 03, 2021, 21:46:55 »
Welll 12000 GBP is a lot of money - and it shows the other side of the price range
and there are the other components that are part of the set, the Nikon FF filter, the AF-1 filter holder (designed for Gelatine -foilters) and the UR2 adapter allowing to mount the FF filter to the AF-1
Wolfgang Rehm
