Author Topic: Does The Nikon AF-S 17-35mm Still Cut It?  (Read 11566 times)
thirtyfivemill
    • THIRTYFIVEMILL.COM
« on: January 05, 2018, 20:01:23 »
I'm in need of a good wide angle zoom which will be paired with my D700. Now I'm fairly sure the Nikon AF-S 17-35mm will pair well with the 12mp D700 but there have been a fair few new comers to the market since I last researched this particular range. For many years (on the recommendation of Bjorn who I met up with in Oslo for a shoot going back just over 20 years ago when I was training as a pilot in Sweden ((Hi Bjorn!!)) I shot with the 20-35 on a D1X and loved that lens and would consider that one again but I'd like something tad wider.
My conundrum has resulted from reading the reviews about the 18-35 AF-S G, the 16-35 VR and the slightly worrying problems some have encountered with failing motors on their 17-35s.
This lens will be used for 60% landscape photography and 40% general. The 2.8 is nice but probably not critical, especially if we take the VR of the 16-35 into the equation. At the moment I flit from one leaning to another, seemingly always coming back to the 17-35mm but that's probably because it's a lens I know.
So, what's the advice folks? Which of those 3 should I picking for my D700 or have I missed a lens I should be considering? There's a thought process that maybe I should break the bank and find a 14-24mm but I'm really trying to keep this purchase to around the £300-500 mark.
Duncan
Re: Does The Nikon AF-S 17-35mm Still Cut It?
« Reply #1 on: January 05, 2018, 20:44:47 »
i have had two of these... the latest was purchased to do IR photography since there are very few wide angle lenses with filter threads that i know work in the IR..  aside from that the lens has always been a reasonably good performer.. there are some complaints about distortion at the wider angles going away at 20mm but as long as you hold it level should be reasonable.. i have the 14-24/2.8G and the Zeiss 15 both require leveling or you run the risk of distortion..
my latest was purchased on ebay for $600 and has an AF squeak which doesn't bother me.. most of the 17-35/2.8D's had this affliction.  so for that price (and its still in the inventory) i would say a good catch.
thirtyfivemill
« Reply #2 on: January 05, 2018, 21:11:06 »
Good grief, that's a blast from the past. I do believe I used to chat to you on photo.net a couple of decades ago, too, Bob!
Thanks for that. I think if this lens was being paired with a D800/810 I might be thinking slightly differently but for the D700 the 17-35 should be a very good lens. But have the optics improved to a point that the cheaper 18-35 or newer 16-35 are actually better performers or does the 17-35 still easily hold it's own in such company, I wonder?
« Reply #3 on: January 05, 2018, 23:02:05 »
i think the 17-35/2.8D would be perfectly fine on the D800/D810.. in fact the intent was to use with my IR conversions which are now all D800's and my recent monochrome sensor conversion is a D800... when the weather gets better and the foliage comes back to the Northeast i will try and compare all of them with the 17-35/2.8D.
back in the day.. all my IR conversions were D200/D300s cams.
i haven't tried the new 16-35/4G
« Reply #4 on: January 05, 2018, 23:05:13 »
The newer 16-35/4 Nikkor is pretty good in IR and the VR actually appears to be of some value.
Good to see you here on NG, Duncan :D
thirtyfivemill
« Reply #5 on: January 05, 2018, 23:26:25 »
Good evening, Bjorn!! Yes, I did promise when I spoke to you on the phone about a year ago. Things take me a little longer these days!! :)
I have to say the 16-35 does appeal to me but there seems to be some sample variation?
« Reply #6 on: January 05, 2018, 23:59:44 »
Probably. Lots of the modern designs have production tolerances that sometimes bring the final product out of spec. If you purchase from a decent dealer should be no problem getting a replacement, though.
gryphon1911
  • Looking For The Best Light
« Reply #7 on: January 06, 2018, 00:03:20 »
If you don't mind non-Nikon brand lenses, you might also want to consider the Tokina 16-28/2.8 and the Tamron 15-30/2.8 VC.
KEH has the Tokina right now for a bit over $500USD.
Andrew
thirtyfivemill
« Reply #8 on: January 06, 2018, 00:14:11 »
Yes, good point. I'll take another look at that one. Now I thought you'd be firmly on the side of the 17-35mm. As I recall that was your staple wide zoom for many a year?
thirtyfivemill
« Reply #9 on: January 06, 2018, 00:16:49 »
Thanks Andrew. I admit to having always stuck firmly to the Nikons for standard primes and zooms. I've gone off piste fairly often with my macro lenses, which is 90% of what I shoot but with landscape and urban/street I've stuck to Nikon lenses exclusively and may be getting a bit long in the tooth to change now. :)
« Reply #10 on: January 06, 2018, 00:19:41 »
i'd buy the 17-35/2.8D before i'd buy the non-nikon... especially since it can be had so inexpensively on the used market.
thirtyfivemill
« Reply #11 on: January 06, 2018, 01:46:35 »
Yep, that would be inclination, too, Bob.
« Reply #12 on: January 06, 2018, 09:58:52 »
I liked the 17-35 on he D700 and continue to do so the Df. It behaves well and predictable and is quite sturdy.
« Reply #13 on: January 06, 2018, 10:48:44 »
+1
« Reply #14 on: January 06, 2018, 18:53:14 »
I like the 17-35 also on the D600 and D800E
