Author Topic: Does The Nikon AF-S 17-35mm Still Cut It?  (Read 11567 times)
jgould2
Re: Does The Nikon AF-S 17-35mm Still Cut It?
« Reply #30 on: January 30, 2018, 15:37:40 »
Hi Duncan.
I consider the 17-35 f/2.8 to be a top-notch lens, so much so that I haven't purchased a 16-35 f/4 even though it has VR. I use mine primarily on my D700 and D3s. I use it more than my 14-24 f/2.8 because I have filter systems for it.
JIM
Erden Sizgek
    • erden sizgek photography
« Reply #31 on: March 07, 2018, 12:06:49 »
About one year ago, I had been through the same decission making study to choose one of these lenses. Finally, I came to the conclusion of buying 17-35 f2.8D AF-ED lens and I purchased the last lens available in Australian market. It works perfect with D800 for visible and fully converted D3200 for IR.
Gil Aegerter
    • @gil.aegerter on Instagram
« Reply #32 on: March 07, 2018, 15:39:32 »
I've had the 17-35mm and currently have the 18-35mm G lens. The older lens, while sharp, was notable for fringing on the D300 I used it with. The 18-35mm is a great lens on my D610 and D5200. It's much lighter for longer backpacking trips. But it is also not as robust for hard use.
Lotsa Nikon gear.
Lotsa Minolta gear.
