Author Topic: [Theme] minimalist images  (Read 396954 times)
the solitaire
Re: [Theme] minimalist images
« Reply #735 on: April 27, 2016, 14:32:48 »
_DSC7228 by b j, on Flickr
DSC_5597-Edit by b j, on Flickr
DSC_5417-Edit-Edit by b j, on Flickr
DSC_1624 by b j, on Flickr
Buddy
« Reply #736 on: April 28, 2016, 23:38:15 »
Nice lights
« Reply #737 on: April 28, 2016, 23:54:55 »
The camera body is really nice. Like the Sun is shining from it :)
the solitaire
« Reply #738 on: April 29, 2016, 10:16:09 »
Thank you Jakov. The idea for this photo was one of my girlfriend. I had tha camera on the dashboard of our car while we passed a lit store sign at night. She saw the image at the moment the light shone out through the lens. From a little experimenting I found this works best with my 105mm lens on the F which gives the most even lighting with a small sized lens. I guess other, longer tele lenses will do well too, but they are bigger of course.
Buddy
« Reply #739 on: April 29, 2016, 10:23:16 »
Buddy, how many girlfriends do you have  ;D
The idea is great, and yes, a lens with a 77mm thread might look even better... worth experimenting :)
the solitaire
« Reply #740 on: April 29, 2016, 12:24:47 »
One girlfriend with millions of ideas Jakov  ;D
I could try a similar shot of my F3 and mount an 85mm f1,4 lens on it. Not sure if the magnification effect of the 85mm lens gives off an even lightbulb like the one through the 105mm but it certainly is worth a try.
The technical execution is really simple. Camera on tripod in front of an off-white interior door with a lightsource pointed at the door, but behind the camera. Shot taken handheld with a 50'ish mm lens
Buddy
the solitaire
« Reply #741 on: May 01, 2016, 00:05:11 »
Tried this today and regardless of the angle and distance I took it just did not work. With the 85mm f1,4 I just get a faint spot on th ecenter of th elens but not the clear edge I got with the 105mm. Tried it with the 105mm on my F3 and it worked fine again. Not quite certain about the math behind it but I will work that out
Buddy
« Reply #742 on: May 01, 2016, 00:17:40 »
Was the aperture fully open?
I hope you get it :)
Show us the faint spot :)
the solitaire
« Reply #743 on: May 01, 2016, 01:24:17 »
I will process the files tomorrow. I also made a few shots with the 105mm mounted on the F3 so I will at least have something to show. :)
Buddy
the solitaire
« Reply #744 on: May 01, 2016, 02:17:17 »
moved to camera talk :)
Buddy
« Reply #745 on: May 01, 2016, 07:00:27 »
Solitaire: consider moving the camera shots, nicely minimalistic as they are, to the appropriate thread in Camera Talk. As these are your own posts moving ought to be feasible. If not then an Amin can do this for you.
Joost Bollens
« Reply #746 on: May 01, 2016, 21:46:43 »
at the place where I live...
« Reply #747 on: May 02, 2016, 01:40:42 »
A detail of a kind of  the Areca Palm...
« Reply #748 on: May 02, 2016, 20:18:15 »
Buddy (the solitaire) - I like each of your shots. Very creative and story-telling.
« Reply #749 on: May 02, 2016, 21:24:12 »
'seafarer's highway' (posted here, but may fit 'best unsharp photo' as well)
