Author Topic: April 2025  (Read 51524 times)
Re: April 2025
« Reply #135 on: April 09, 2025, 16:29:02 »
April 9
Wijenberg castle, Echteld
D850  24-70mm f/2.8g
Ian Watson
Re: April 2025
« Reply #136 on: April 09, 2025, 21:40:27 »
I am reprocessing photographs of my black-and-white negatives. Having fallen under the influence of Bruce Fraser and Jeff Schewe, I attempted to reduce the appearance of the grain using the Surface Blur filter in Photoshop, applied through a surface mask. Then I sharpened with an edge mask. The grain is still there, of course, but much less obtrusive.
This photograph is from Cozumel, México, in 2013. The film is Ilford FP4+ and the lens was Nikon's 85mm f/1.4D
Re: April 2025
« Reply #137 on: April 09, 2025, 21:50:42 »
Tulip time
D5 AF-D 180/2.8
Re: April 2025
« Reply #138 on: April 09, 2025, 22:42:32 »
Focusing on the rising sun.
Re: April 2025
« Reply #139 on: April 09, 2025, 22:44:41 »
An example of the bad results you'll get with the old Nikkor 200mm f/4 AI lens on the Zf.
Road Warrior
Re: April 2025
« Reply #140 on: April 09, 2025, 22:56:02 »
I like the composition Birna!
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: April 2025
« Reply #141 on: April 09, 2025, 23:15:37 »
Road Warrior
Birna, The truth is that I have a lot of Nikon lenses, but I don't have either the NIKKOR 200mm F/4 AI or the NIKKOR 105mm F2.5.
Re: April 2025
« Reply #142 on: April 09, 2025, 23:48:55 »
The various incarnations of the Nikkor 105mm f/2.5 are legendary and today, one can pick up a nice sample quite cheap. Recommended if you don't have the lens already. I used to say the 105 and the Df were a synergetic combination, not entirely sure this still holds for the Zf, but that is mostly because of the handling with an FTZ attached and not due to bad optics.
Re: April 2025
« Reply #143 on: April 10, 2025, 00:21:28 »
Road Warrior
  Maybe "bad" has more than one meaning...?  ;)
Re: April 2025
« Reply #144 on: April 10, 2025, 00:26:14 »
Hello, it's a screen print.
  Thank you for sharing it Arturo.
Re: April 2025
« Reply #145 on: April 10, 2025, 02:01:14 »
it is a very fine transition from the dead sharp column to the slightly unsharp hair and heads of the couple doing their selfie shot
Re: April 2025
« Reply #146 on: April 10, 2025, 02:02:43 »
Road Warrior
superb foto
Re: April 2025
« Reply #147 on: April 10, 2025, 02:04:33 »
I do own several 200mm lenses the 4/200 Micro Nikkor is one of my favourites
Lars Hansen
  • Zealand, Denmark
Re: April 2025
« Reply #148 on: April 10, 2025, 02:18:03 »
Good you did, Akira - beautiful sunrise and the light being reflected over the buildings!
Re: April 2025
« Reply #149 on: April 10, 2025, 03:29:51 »
Thank you, Lars.  I shot another image from the top of the emergency stairs of my place.  But while I found this scene while I went down to go back to my room.
