Author Topic: April 2025  (Read 66152 times)
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: April 2025
« Reply #105 on: April 08, 2025, 10:33:58 »
Frank probably used the AFS version, which is the current model. I have this plus the older manual 200/2 AIS, the latter is also very good however the modern version is stellar.
Thanks Birna
Re: April 2025
« Reply #106 on: April 08, 2025, 10:43:33 »
Suffice it to say the other cars around did not show this pattern - or colours.
Local condition then. I was lightly hoping for a case of UV metamerism :)
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #107 on: April 08, 2025, 11:49:11 »
Too big for her
Re: April 2025
« Reply #108 on: April 08, 2025, 12:07:39 »
I'm a painter, not a photography expert, but it seems to be an interesting lens. I don't know the model or age.
Hi Arturo show us some of your paintings!
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #109 on: April 08, 2025, 12:17:02 »
Hello, it's a screen print.
Re: April 2025
« Reply #110 on: April 08, 2025, 12:27:21 »
Love this Arturo!
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #111 on: April 08, 2025, 12:38:12 »
Love this Arturo!
Thanks. The other day I painted a writer from Madrid. Author of Historias del Kronen
Re: April 2025
« Reply #112 on: April 08, 2025, 12:46:53 »
That is exactly the point. The Tesla is black to the naked eye, but definitively two-coloured under UV. Could be a paint job after a damage, or something that is common to the model. The latter needs more samples to verify, of course.
KarlMera
Re: April 2025
« Reply #113 on: April 08, 2025, 13:08:39 »
Two friends
Re: April 2025
« Reply #114 on: April 08, 2025, 19:17:30 »
Great stuff, Arturo.
Oaks under sand
D5 24-70vr
Re: April 2025
« Reply #115 on: April 08, 2025, 20:04:53 »
Could it be reflections, perhaps form the sky, enhanced by the UV rendition? As I recall UV tends to enhance surface reflections.
The symbolism is pretty clear though.   ;)
Re: April 2025
« Reply #116 on: April 08, 2025, 21:25:07 »
I did shoot nearby cars, also black ones, and none of these showed any metamerism under UV. The captures were within a short time span, too.
It is indeed true that UV enhances surface reflections, thus alternate interpretations might be in effect. I need to seek out a couple more Teslas to check their UV appearance. Shouldn't be too hard as they are pretty thick around here. Tesla paintwork does have a reputation of being poorly conducted. Not uncommon to observe refurbished Teslas.
Re: April 2025
« Reply #117 on: April 08, 2025, 23:08:38 »
Now I’m thinking about resurrecting the D40 and finding a UV filter to shoot the neighbor’s Tesla … :)  Which filter did you use ?
Re: April 2025
« Reply #118 on: April 08, 2025, 23:43:07 »
Baader U -- standard UV approach. Camera was one of my full-spectrum modified GH2 bodies and lens the Coastal/Jenoptik 60mm f/4 APO. But you ought to get something out of most vintage 50mm lenses with the D40, if memory serves.
Re: April 2025
« Reply #119 on: April 08, 2025, 23:51:25 »
I have a 35/3.5 Kuribayashi somewhere, which has good transmission if I remembrer well, but I need to procure the UV filter.
