Author Topic: April 2025  (Read 51503 times)
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: April 2025
« Reply #150 on: April 10, 2025, 08:02:29 »
I do own several 200mm lenses the 4/200 Micro Nikkor is one of my favourites
The Micro-NIKKOR 200mm 1:4 I do have, I use it to take pictures of frogs and other things, I like it
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #151 on: April 10, 2025, 08:33:59 »
The various incarnations of the Nikkor 105mm f/2.5 are legendary and today, one can pick up a nice sample quite cheap. Recommended if you don't have the lens already. I used to say the 105 and the Df were a synergetic combination, not entirely sure this still holds for the Zf, but that is mostly because of the handling with an FTZ attached and not due to bad optics.
I've read good reviews about the 105 and almost bought one on occasion. All the lenses I own are secondhand and old. I use them with the Nikon D750, manually. I haven't studied photography at all. I learn by taking photos on my own, and with you and the people on the forum as well.
Re: April 2025
« Reply #152 on: April 10, 2025, 09:39:14 »
Cars
D850  afs 24-70mm f/2.8G
Ran the raw file through photoninja and finished in PS.
Re: April 2025
« Reply #153 on: April 10, 2025, 10:50:34 »
The 'Grease' Willow Salix pentandra is a regular component of the riparian ecosystem along our local river. The female catkins hibernate and open in spring to disperse the fluffy seeds, long before leaf-out occurs. Thus the trees are very visible in the otherwise drab springtime landscape. The vernacular name (Norwegian 'istervier', which means grease willow) is ancient Norse and probably refer to the catkins, which do look like clumps of lard or grease at distance. Another possibility is the foliage which is very shiny and covered with a wax-like cuticula.
I shot with the Nikkor 200/4 Ai on my Zf and had to go to lengths to tame all the CA (lateral and axial) caused by the the numerous twigs and branches acting as a diffraction grating (?). About the worst case I've ever seen.
Re: April 2025
« Reply #154 on: April 10, 2025, 11:13:26 »
Cars
I assume PN lacks a profile for the D850 so colours were a bit off? In fact, works well here.
Re: April 2025
« Reply #155 on: April 10, 2025, 12:30:38 »
It is a Df profile which i tweaked, and even adjusted the wb in ps and indeed i think the colours match the style of the old americans, thanks Birna.
KarlMera
Re: April 2025
« Reply #156 on: April 10, 2025, 15:07:07 »
Detailed
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #157 on: April 10, 2025, 15:41:37 »
Cars
I love the FORD brand and the red clothespins
Re: April 2025
« Reply #158 on: April 11, 2025, 09:52:51 »
Ich got several 105er, starting from an oldish 3.5/105 without AI that can be used on the FTZ anyway. Yet I do love the Macro Z-Nikkor 2.8/105 MC and the 1.4/105E for the F-System
KarlMera
Re: April 2025
« Reply #159 on: April 11, 2025, 11:16:49 »
Happy
KarlMera
Re: April 2025
« Reply #160 on: April 11, 2025, 11:34:21 »
Is that the Q for Bronica?
Re: April 2025
« Reply #161 on: April 11, 2025, 11:43:15 »
Thank you Arturo.
Re: April 2025
« Reply #162 on: April 11, 2025, 14:08:47 »
Here is Carlos, special guest musician in the last masterclass we had this week.
  D5, 70=200 2.8fl
Re: April 2025
« Reply #163 on: April 11, 2025, 15:46:48 »
no it is a Nikkor Auto Nikon Koakgu in F Mount, but I cannot find it. IIRC it came with the PB-4 and PF-4 Bellows / Slide Copier as a set, but I might be mistaken and it was the 3.5/55mm
Re: April 2025
« Reply #164 on: April 11, 2025, 15:58:57 »
I took this picture today but exacty 8 years ago today. in the cherry blossom. I still love this picture very much.
D500 & 300PF
