Author Topic: April 2025  (Read 52991 times)
Re: April 2025
« Reply #120 on: April 09, 2025, 00:07:48 »
The Kuri will do very well. The D40 should get you some UV shots without further modification too, however a tripod likely is required due to long exposures.
Re: April 2025
« Reply #121 on: April 09, 2025, 05:32:22 »
Good photo, but what exactly is the objective?
I feel the lens denomination as 2/200VR is clear ... The next gen is called VRII and the one before has no VR at all. Although Roland lists two versions on his page any my serial number is above 300,000
http://www.photosynthesis.co.nz/nikon/serialno.html
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: April 2025
« Reply #122 on: April 09, 2025, 09:14:54 »
Thanks. I see it's a very expensive lens, the old one. Your photo of the bike is interesting. At first, I thought it was a miniature, a toy bike.
Re: April 2025
« Reply #123 on: April 09, 2025, 09:20:46 »
The first AFS version of the 200/2 definitively had VR. Did you have the older manual AI/AiS 200/2 in mind?
Re: April 2025
« Reply #124 on: April 09, 2025, 09:38:36 »
The heavy lens and camera suit well as a "stabiliser"
Re: April 2025
« Reply #125 on: April 09, 2025, 09:42:33 »
What I say is: mine is the first VR which automatically means it is AF-S and the previous versions had no VR. Mine was manufactured after 2006. Looks like that:
https://www.photosynthesis.co.nz/nikon/afs2002.jpg
I was mistaken only in so far that I thought there was an AF-D version earlier. Which was not the case:
KarlMera
Re: April 2025
« Reply #126 on: April 09, 2025, 10:46:05 »
Magic powers
Re: April 2025
« Reply #127 on: April 09, 2025, 10:51:20 »
Magic powers
Your style is recognizable
Re: April 2025
« Reply #128 on: April 09, 2025, 10:54:17 »
.. and now with built-in zooming :)
Re: April 2025
« Reply #129 on: April 09, 2025, 11:03:38 »
To round up the 200/2 trivia exchanges: I originally had the 200/2 Ai, later changed to the latest AiS 'N' version so I could use  [gel]filters. Later I acquired the first sample of the AFS 200/2 VR to arrive in my country. I have shot with the latest VR-II version, however any improvement over my current sample is not very significant and the trade-in costs excessive (I got my AFS 200/2 for a bargain price).
My 200/2 lenses both have very early 2xxx serials.
KarlMera
Re: April 2025
« Reply #130 on: April 09, 2025, 12:04:39 »
Yes, right, its the H X2D BIZ with 1,1/ 21-120 macro, only one combo worldwide was produced .
Re: April 2025
« Reply #131 on: April 09, 2025, 14:15:14 »
Although i couldn't afford one, I've seen some stunning results with the 200mm f2 Arturo
The razor thin d.o.f. is one
The rendering is the next, and fairly unique
Back in the days of film or early DSLR's when ISO was limited, there were some unique shots in low light or indoor events.
Progress with ISO make the last point less competitive nowadays
I'm sure other can give a better list.
Re: April 2025
« Reply #132 on: April 09, 2025, 14:28:12 »
Lots of arguments for getting the AFS 200/2, any version. All moot if one cannot afford it :(
Meanwhile, even the old workhorse, Nikkor 105mm f/2.5, works splendidly with the Zf. This is about the longest of the manual Nikkors that handles well enough with the Zf + FTZ.  The longer focals tend to be unbalanced unless you aim for tripod usage.
This is the AI version which remains my favourite of the many versions of the venerable 105/2.5. Shooting the manual Nikkors now is a breeze more than ever due to the v.2.0 firmware, since you set up the precise definition of the lens (like the Z9) and can dial in the intended aperture for shooting as well (a novel feature not yet seen on the Z9, surprisingly enough). EXIF records now all the info, too.
I also shot a few frames with the Nikkor 200mm f/4 AI, once a favourite  which complements the 105 nicely, however results were not good as bad CA appeared. I'll aim for the 200mm f/3.5 ED-IF or even better, the AFS 200/2 next time :) plenty of room for it  in the new car.
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #133 on: April 09, 2025, 14:53:33 »
I see it's difficult to get one, but you never know.
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #134 on: April 09, 2025, 14:57:33 »
I also shot a few frames with the Nikkor 200mm f/4 AI, once a favourite  which complements the 105 nicely, however results were not good as bad CA appeared. I'll aim for the 200mm f/3.5 ED-IF or even bettetr, the AFS 200/2 net time :) plenty of room for it  in the new car.
Birna, the window photo is very good, but the kids are very bad.
