Author Topic: April 2025  (Read 66175 times)
Re: April 2025
« Reply #165 on: April 11, 2025, 16:08:29 »
no it is a Nikkor Auto Nikon Koakgu in F Mount, but I cannot find it. IIRC it came with the PB-4 and PF-4 Bellows / Slide Copier as a set, but I might be mistaken and it was the 3.5/55mm
Might be the Bellows-Nikkor 105mm f/4 P?
Re: April 2025
« Reply #166 on: April 11, 2025, 16:22:16 »
As soon as I find it, I will report. You are probably right.
Re: April 2025
« Reply #167 on: April 11, 2025, 18:44:08 »
Old church at Hien, province of Gelderland, tower is from 1400 AD.
D850  afs 24-70mm f/2.8
Re: April 2025
« Reply #168 on: April 11, 2025, 18:53:23 »
edit looks like a cross development
Re: April 2025
« Reply #169 on: April 11, 2025, 18:59:05 »
Fons experiments with 3-D photos? The special red-cyan glasses are called for, I presume.
Re: April 2025
« Reply #170 on: April 11, 2025, 19:39:28 »
Frank and Birna excuse, two layer photography with a minute difference in dimensions ;)
Re: April 2025
« Reply #171 on: April 11, 2025, 20:29:38 »
Tried with 3-D glasses and it didn't work. Something with bad parallax intruded.
Re: April 2025
« Reply #172 on: April 11, 2025, 20:47:38 »
Two layers either layer was developed in a different way so for instance one layer by lensprofile the other one without correction hence the colour fringes and the parallax mismatch it all happened without planning! Thanks
Re: April 2025
« Reply #173 on: April 11, 2025, 20:48:31 »
I really liked the images from  a few days ago from Ian (B&W), Akira (sun) and Birna (bad 200mmf2)
Were you happy with the way your PP turned out Ian?
I've only seen this on a tablet screen,  but might have been happy to get this from FP4
it is a very fine transition from the dead sharp column to the slightly unsharp hair and heads of the couple doing their selfie shot
And for me, there's something about what the bokeh does to the blossom that is also enigmatic & pleasing
Re: April 2025
« Reply #174 on: April 11, 2025, 20:52:30 »
Here is Carlos, special guest musician in the last masterclass we had this week.
  D5, 70=200 2.8fl
It feeks like we can almost hear his performance Paco, as well as seeing it !
Re: April 2025
« Reply #175 on: April 11, 2025, 21:15:21 »
Grandson
D5 AF-D 70-180mm Micro Nikkor
Re: April 2025
« Reply #176 on: April 11, 2025, 22:39:47 »
Handsome fellow John.
Re: April 2025
« Reply #177 on: April 11, 2025, 22:43:24 »
Thanks Fons.  Yes he is. In two weeks two years old ;)
Re: April 2025
« Reply #178 on: April 12, 2025, 00:05:14 »
  Thank you Colin. Carlos himself also liked it too!
Re: April 2025
« Reply #179 on: April 12, 2025, 00:06:46 »
Grandson
  Handsome indeed. He looks so big!
