Author Topic: April 2025  (Read 73350 times)
Re: April 2025
« Reply #90 on: April 07, 2025, 11:37:41 »
The Panasonic GF1 with the EL-Nikkor 50mm f/2.8 mounted in its focusing helicoid. This camera has been modified to have M42 mount so allows easy experimentation with various "exotic" lenses. In the case with the EL-Nikkor, I assume even a standard M4/3 camera could have had sufficient register distance to allow mounting the enlarger lens and provide infinity focus. At least the 63mm f/3.5 and 80mm f/5.6 EL-Nikkors would do this on my other GF1/GH2 Panasonics, or even F-mount cameras. (tested: yes, this works also with the non-modified bodies)
The focusing helicoid used here is 15-27mm. The more ubiquitous 17-35mm helicoids are too long for infinity focus.
aerobat
Re: April 2025
« Reply #91 on: April 07, 2025, 20:09:30 »
Massive crop of a photo with the Zf and Voigt 40mm - I love the starburst it produces on the candles
Daniel Diggelmann
Luc
    • Flickr
Re: April 2025
« Reply #92 on: April 07, 2025, 20:52:44 »
Architecture
Z6 + Z 14-30mm
Z6_DSC5947 by Luc de Schepper, on Flickr
Re: April 2025
« Reply #93 on: April 07, 2025, 21:57:58 »
Birna says that this is an "essential lens" and I feel she is right. Of course it is expensive but the rendering is just stunning
D850 & 2/200VR @f/2.0
Re: April 2025
« Reply #94 on: April 07, 2025, 23:31:40 »
I agree with you and love the results Frank
Re: April 2025
« Reply #95 on: April 07, 2025, 23:33:00 »
I finally managed to get some pictures of a visiting Greater Spotted Woodpecker feeding in our garden
(taken through double glazed windows :( )
Re: April 2025
« Reply #96 on: April 08, 2025, 00:44:46 »
We hear a lot about Teslas these days, so interesting to see how it looks in UV. Where true colours are false :)
Hand-held test shot by the way, run straight through Photo Ninja.
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: April 2025
« Reply #97 on: April 08, 2025, 07:23:29 »
Good photo, but what exactly is the objective?
Re: April 2025
« Reply #98 on: April 08, 2025, 08:46:09 »
Showing the photo?
Re: April 2025
« Reply #99 on: April 08, 2025, 08:48:18 »
Grape hyacinth
Zf   Voigtländer 65mm f/2
Re: April 2025
« Reply #100 on: April 08, 2025, 08:51:39 »
Vespa
ARTUROARTISTA
    • APM Pintor
Re: April 2025
« Reply #101 on: April 08, 2025, 09:18:01 »
Showing the photo?
I'm a painter, not a photography expert, but it seems to be an interesting lens. I don't know the model or age.
Re: April 2025
« Reply #102 on: April 08, 2025, 10:07:38 »
Intriguing pattern. Is it only because of shadows or is something else in play ?
Re: April 2025
« Reply #103 on: April 08, 2025, 10:16:49 »
Well, it's UV. What meets the eye isn't necessary what the camera sees. One might read more into the false/true colours if that's one's inclination.
Suffice it to say the other cars around did not show this pattern - or colours.
Re: April 2025
« Reply #104 on: April 08, 2025, 10:19:09 »
Frank probably used the AFS version, which is the current model. I have this plus the older manual 200/2 AIS, the latter is also very good however the modern version is stellar.
