Author Topic: [Theme]: Wide IR  (Read 36358 times)
Re: [Theme]: Wide IR
« Reply #15 on: July 04, 2017, 12:36:16 »
I'm crazy about sunflowers too! Ill post one more later.
  I think my filter is a longpass around 720nm.
Cut with a dremmel from here:https://www.edmundoptics.com/optics/optical-filters/longpass-edge-filters/optical-cast-infrared-ir-longpass-filters/#f=categories_s
  Im going to NY in August and the plan is to get a new converted camera from lifepixel. Lola is fun but the filter is all scratched. So 600mn has more color humm....
« Reply #16 on: July 04, 2017, 13:33:55 »
The 600nm has more color because it doesn't filter out all visible light. It let's through the entire wavelength of red channel and perhaps a bit of orange and yellow too. Bjørn likes to call it semi-IR, and that is my preferred way of shooting in IR.
I fell in love with the 600nm way of shooting when I started with a multi-spectrum broad-band D70 and a 16/3.5 fish-eye that has the R60 filter inside. Later I used a gel for the 8mm Sigma fish-eye. In any case I could start seeing what I was shooting. Later Erik modified a D200 for me so I don't have to play with gels and filters :)
Here are some examples:
http://nikongear.net/revival/index.php/topic,634.0.html
http://nikongear.net/revival/index.php/topic,2190.0.html
« Reply #17 on: July 04, 2017, 14:26:21 »
Yes Jakov, I clearly remember those post. They are one more reason why I tried in the first place  ;)
   The jury is still out about the kind of filter and if it is going to be a full fx or dx sensor. So far the experience with the d80 IR "Lola", all the way from the modification has been amazing for me.
   "Communications from the lab"
« Reply #18 on: July 04, 2017, 15:12:53 »
WOW, sunflower and Tesla  :o
« Reply #19 on: August 05, 2017, 17:27:30 »
My d80´s filter is so scratched that I have to throw away many images. The plan is to replace it with a "lifepixel" converted either d3300 or d5300 720nm ir. In the mean time, I still enjoy very much what "Lola" can produce.
    Creatures by the pool
« Reply #20 on: August 05, 2017, 22:56:46 »
« Reply #21 on: August 05, 2017, 22:57:21 »
Olivier
  • Olivier Anthony
« Reply #22 on: August 06, 2017, 04:52:29 »
Some great pictures here... My widest lens on the V1 is 27mm equivalent, so not so wide... The solution is to stitch panoramas.
Bob, I love the backlit tree!
« Reply #23 on: August 06, 2017, 12:22:45 »
RG830
RG715 - thin.. so almost a RG695 or so
« Reply #24 on: August 06, 2017, 22:59:05 »
Given the artists that post here, this topic is going to be a real treat!
Bob, Paco, Olivier, Fons et al.
« Reply #25 on: August 06, 2017, 23:00:25 »
Back home.
Looking at some images I made in Cres of my daughter using wide IR gear.
D200 and 10.5DX fish-eye.
« Reply #26 on: August 06, 2017, 23:30:43 »
« Reply #27 on: August 09, 2017, 14:02:14 »
La Muela, Spain.
« Reply #28 on: August 10, 2017, 18:57:43 »
La Muela, Spain.
Impressive. I like it, great shot!
« Reply #29 on: August 10, 2017, 19:11:32 »
Thank you Thomas.
