Author Topic: May 2020  (Read 101100 times)
Re: May 2020
« Reply #75 on: May 07, 2020, 15:11:44 »
Re: May 2020
« Reply #76 on: May 07, 2020, 15:13:10 »
May 7.  Iris.
Lovely. The transparant background works great.
Re: May 2020
« Reply #77 on: May 07, 2020, 15:41:44 »
Agreed. I very much enjoyed the way you took to the subject
Re: May 2020
« Reply #78 on: May 07, 2020, 15:41:49 »
May 7.  Iris.
Simple and lovely.
Re: May 2020
« Reply #79 on: May 07, 2020, 16:20:37 »
May 7
jonge hengst
Z6 - 70-300mm f/4.5-5.6E
Thanks!
Re: May 2020
« Reply #80 on: May 07, 2020, 17:15:21 »
A warm Spring day
Z7  CV50/1.8 Ultron
Re: May 2020
« Reply #81 on: May 07, 2020, 17:16:40 »
Simple and lovely.
Thank you, John, Paco and Jack.  I always love the petals of the iris rendered this way.
Re: May 2020
« Reply #82 on: May 07, 2020, 17:22:56 »
A warm Spring day
Z7  CV50/1.8 Ultron
I like the color combination of the lovely purple against the light green and yellow background.
Re: May 2020
« Reply #83 on: May 07, 2020, 18:09:00 »
Thanks.
The pastel colours and 3d effects of this lens are unique.    ( The lens has an optical 7/6 design and used brand names are Voigtlander, Zeiss Planar and Rollei. The Design is by Albrecht Wilhelm Tronnier for Voigtlander (Zeiss)
Re: May 2020
« Reply #84 on: May 07, 2020, 19:44:02 »
Thanks.
Yes. And you put it to good use!
Re: May 2020
« Reply #85 on: May 07, 2020, 21:14:48 »
Thanks.
Thank you for the technical detail.  As an (almost) exclusive standard lens shooter, I feel like trying one myself.  To me, a 50/1.8 (or a 50/2.0)  is "the" most versatile lens.
Re: May 2020
« Reply #86 on: May 07, 2020, 22:00:37 »
Thanks Paco
I can recommend the lens. Performance is pretty good with charming color and the drawbacks limited, I  must say.  A bit of vignetting and loca when used wide open. Easy to focus, especially on the Z6/7.
Filter size is 49mm, so I used a stepup ring to use a 52mm Sun hood (HN-3)
Finally I can use it (to infinity) on a Nikon ;)
Re: May 2020
« Reply #87 on: May 07, 2020, 22:58:57 »
Here is my first Z6 post in this thread
Re: May 2020
« Reply #88 on: May 08, 2020, 00:21:21 »
They look sooo good Frank
  Light with no light and no light with light  :o
  D500, 70-300mm vr
Re: May 2020
« Reply #89 on: May 08, 2020, 08:52:44 »
The Aspargus is of great quality
The Kit-Lens 4/24-70S is superb
