Author Topic: March 2019  (Read 133496 times)
Re: March 2019
« Reply #150 on: March 09, 2019, 19:15:42 »
Clear message (?)
Snow, wind, and the V1
Norwegian weather so blue, so blue...
Re: March 2019
« Reply #151 on: March 09, 2019, 21:05:29 »
Congrats on the heavy new gear Frank.  Is it dirty?
Monday check & clean at NPS, esp. the VR makes an unpleasent sound similar to my former rental 105VR
Re: March 2019
« Reply #152 on: March 09, 2019, 21:19:54 »
I think my back would make an unpleasant sound hauling that 200mm around.
Don’t forget to warm-up and stretch before sessions with it!
Im looking forward to seeing what you capture through those lenses.
Re: March 2019
« Reply #153 on: March 09, 2019, 23:34:41 »
It's just 2.5kg -- even I can manage it :D
Re: March 2019
« Reply #154 on: March 10, 2019, 01:20:25 »
z6 with 55mm 3.5 pretty close down. 2.5 sg shutter speed.
Re: March 2019
« Reply #155 on: March 10, 2019, 02:53:53 »
Looks bigger. I'm off tomorrow to photograph rowers with the venerable 300mm f/2.8 ED-IF which is heavy enough.
Re: March 2019
« Reply #156 on: March 10, 2019, 08:41:01 »
Birna, it's a 2.9kg monster...
Frank, congrats on your purchase of new gear!
Re: March 2019
« Reply #157 on: March 10, 2019, 08:43:52 »
March 10.
Dawn in the land of rising sun with sinking economy...
Re: March 2019
« Reply #158 on: March 10, 2019, 09:03:52 »
Also 2.5 kg ....
Re: March 2019
« Reply #159 on: March 10, 2019, 09:18:52 »
IIRC both are same weight, same size. 100mm more, one stop less...
Re: March 2019
« Reply #160 on: March 10, 2019, 10:07:11 »
The af-s 300mm f/2.8 does 3,1 kgs.
Do you go out with monopod or not?
Re: March 2019
« Reply #161 on: March 10, 2019, 11:26:23 »
I tried a tripod a few weeks back but rather clumsy so I most hand held or sat and rested it on a knee. Fortunately rowers travel mostly in a horizontal plane and always in the same direction. Z6 IBIS really helps.
Re: March 2019
« Reply #162 on: March 10, 2019, 13:14:49 »
Test shooting lenses in preparation for a journey into the world of false-colour IR emulated (IE) images. The 35-200/3.5-4.5 Nikkor normally is a good performer -- at least my copy is -- but didn't work too well on the IE test. There are too much residual chromatic aberrations and a tendency to form a hot spot. The search continues.
35-200/3.5-4.5 Nikkor @35mm, Fuji S5Pro.
(in case any one should wonder, the white stuff on ground is freshly fallen snow. Which loses a lot of its intense whiteness with IE)
Re: March 2019
« Reply #163 on: March 10, 2019, 14:39:47 »
Interesting Birna. Do you use an extra filter for the IE images?
Re: March 2019
« Reply #164 on: March 10, 2019, 14:40:43 »
Storm weather here.
Damage in the Forsythia?
D850-200/2
