Author Topic: Show your 105mm images  (Read 51133 times)
Re: Show your 105mm images
« Reply #45 on: January 03, 2019, 00:17:34 »
Or about half the field of view of the ubiquitous 50mm "standard" lens of the era?
Most "standard" lenses for 35mm format are (or were) actually 51.6mm, so doubling will give 103mm, which is very close to 105mm ...
« Reply #46 on: January 03, 2019, 03:55:21 »
A great sequence here Andrew - I like the first and last - "the aerials".
Local handball, 105/1.4 with D500
BillO
  • Cruising the US in a Motorhome
« Reply #47 on: January 03, 2019, 04:09:20 »
In all these posts so far I think that I only saw one image with my favorite 105, so I thought that I would contribute some from my 105/4 micro-nikkor.
First is a drop of cedar oil being forced from the tree in the hot Texas sun.  Then a grasshopper trying to hitch a ride on my car windshield and final a Texas wildflower along the roadside.  Except for the grasshopper at f5.6, the rest at f4 on either D600 or D610:
Regards,
Bill Oliver
« Reply #48 on: January 03, 2019, 11:55:27 »
Stacked 105/4 Micro + 105/4 Bellows.
« Reply #49 on: January 03, 2019, 12:02:20 »
A signature image often used by me as the opening of a slide show presentation. With or without title of show.
One of my first digital UV captures with the legendary UV-Nikkor 105/4.5 (camera: D1 -- yes, the picture is 'ancient')
« Reply #50 on: January 03, 2019, 12:40:02 »
Another capture with the 105/1.8 Nikkor.
« Reply #51 on: January 03, 2019, 12:43:24 »
looks biological but is it edible?
« Reply #52 on: January 03, 2019, 12:44:14 »
I was quite fond of the 105/2.8 AF in its time, despite the horrible AF operation and the A/M shift collar that could break and split the lens into two halves. These issues were solved permanently by epoxy glue and taping the collar with sturdy 'hockey stick' tape (same kind used for cycles).
« Reply #53 on: January 03, 2019, 12:45:06 »
Barnacles. Mercilessly cutting through flesh if you step on them.
« Reply #54 on: January 03, 2019, 13:15:56 »
Another early UV-Nikkor 105/4.5 picture. (F4 ie. gasp!!! film)
Asle F
  • Hovet, Norway
« Reply #55 on: January 03, 2019, 16:24:25 »
« Reply #56 on: January 03, 2019, 17:57:50 »
I remember that quite well Birna, one of your nicest ones!!! Really like its Zen-like simplicity and those elegant colors!
« Reply #57 on: January 03, 2019, 22:12:46 »
grand piece of cinematic photography. Wow.
« Reply #58 on: January 03, 2019, 22:42:43 »
For many years, I ran the 105/2.8 Micro-Nikkors AF and AiS concurrently. This is the latter.
« Reply #59 on: January 03, 2019, 22:54:18 »
Another with the 105/2.8 Micro AIS. My little red Peugeot after rough driving on bad roads :)
