Author Topic: "Starter kit" lenses - advice on choice?  (Read 10656 times)
simato73
« on: February 24, 2017, 17:35:14 »
Hi,
I am shopping for a camera/lens kit to gift to my nephew for his 18th birthday.
It will be a Nikon DSLR since his brother already has one - whatever lenses they accumulate they can share.
I will be quizzing him this weekend to understand whether a D5500 or a D7x00 (x= 1, 2) is best for him.
In terms of lens, since I will most likely be forced to buy a kit, I can choose among the 18-55, 18-105 or 18-140.
I am not that keen on the 18-55 although it is not already totally written off.
Any comment on how the 18-105 and 18-140 compare? Is any of them definitely to be avoided?
Cheers
Simone Tomasi
Re: "Starter kit" lenses - advice on choice?
« Reply #1 on: February 24, 2017, 18:01:32 »
Simone, I'm afraid I cannot comment on your main question: 18-105 vs. 18-140.
However, it would be careful if you would ever go for 18-55.  The latest, AF-P version may not be compatible with the body that the brother already has.  The AF of AF-P is noticeably faster than the AF-S version (I did a direct comparison with AF-P on D3400 and AF-S on D5500 at a Nikon showroom), and thus AF-P is preferable.  However, even the bodies which can use AF-P, there are some limitations.  D5500 (updated with the latest firmware), D5600 and D3400 are the only bodies that are fully compatible with AF-P.
simato73
« Reply #2 on: February 24, 2017, 18:57:19 »
Akira,
Thanks for the alert, I was not aware of it.
The older brother has a D7000 and the venerable 18-70 plus a 70-300 VR that I bought for his 18th birthday a few years ago.
I'll probably steer clear of the 18-55 to avoid complications.
Simone Tomasi
« Reply #3 on: February 24, 2017, 19:02:05 »
The 18-140 is an overlooked lens which is very capable on its own. Really excellent optics in that one. Unfortunately it hot-spots in IR, otherwise I had purchased it myself long ago.
(DX only lenses for me are to be used on one of my modified IR cameras, which at present also are DX)
JohnMM
« Reply #4 on: February 24, 2017, 19:31:46 »
The D3300 is still available with the AF-P as kit lens.
OCD
  • Obsessive Corgi Disorder
« Reply #5 on: February 24, 2017, 19:40:32 »
I purchased the D5300 kit with the 18-55 and 70-300 AF-P lenses for my wife, and am pleased with the performance.  Good price right now too:  https://www.bhphotovideo.com/c/product/1294166-REG/nikon_1579_d5300_dslr_camera_dual.html
« Reply #6 on: February 24, 2017, 19:41:51 »
How about a D610 and a 50/1.8G? It should cost more or less the same...
All you have to tell your nephew is:
"if you cannot make a good image with this combination, be certain it's not the gear that is at fault" :)
Matthew Currie
« Reply #7 on: February 24, 2017, 21:42:36 »
I got my D3200 with the 18-55 VR lens, and it was not bad optically, but it's really pretty cheaply made, and it wore out. Later ones at least have improved enough to have a non rotating front element, but still pretty cheaply made.
My wife when she got a D7100 got the 18-140 as a kit lens, and it's behaved very well.  It is, as mentioned above, very sharp, and with that range it ends up being a very good all-around zoom.  It's traveled around quite a bit in the last three years, and given good service.  Not a great bargain when bought separately, it's a pretty good buy as a kit lens.
I thought of getting one when my 18-55 went south, but decided on a cut rate used 16-85 instead, because I wanted the width. I like that one,  but the 18-140 is sharper and usually less expensive.
simato73
« Reply #8 on: February 24, 2017, 21:43:55 »
I think this combo is not what he needs/wants right now, but thanks for the idea.
Having just had a chat with his brother, I lean toward a D5500, perhaps with a 18-140.
PS: Cross-posted with Matthew
Simone Tomasi
simato73
« Reply #9 on: February 24, 2017, 21:44:38 »
Thanks, interesting but unfortunately living in Europe buying from B&H is not as convenient.
Simone Tomasi
« Reply #10 on: February 24, 2017, 22:38:02 »
D3300 and D5300 is almost compatible with AF-P.  Here in Japan, Nikon just released D5300/AF-P kit, probably because they want to clear the surplus stock.
OCD
« Reply #11 on: February 24, 2017, 22:58:17 »
D5300 is compatible with AF-P, although might need to update the firmware.  Mine came good to go with the AF-P lenses, there is a menu setting to turn VR on or off since there is no VR switch on the lens itself.  The lenses focus quickly and quietly, a nice kit me thinks.  And I agree...Nikon seems to be trying to clear some inventory....as usual....haha.
« Reply #12 on: February 24, 2017, 23:17:39 »
Apparently D5300 is a "preferred" D5x00 camera here in NG with the integrated GPS.  Hope you enjoy your purchase!
« Reply #13 on: February 24, 2017, 23:19:59 »
Just remember to load an aGPS file into the D5300, otherwise the GPS never really works. It will happily deplete the battery whilst searching for a satellite fix :D With the aGPS installed, it gets the fix in normal time.
The camera manual and/or Nikon's site(s) contain the instructions required.
simato73
« Reply #14 on: February 24, 2017, 23:22:27 »
Good call, this would interest me... but the nikon ship has sailed for me (apart from old Nikkor lenses).
The camera is for my nephew and I do hope he enjoys it.
Currently deciding between a few good offers, D5300 +18-140 or D5500 + 18-140 or D5500 + 18-55 (P).
I may decide to be generous and throw in also a 35 DX :)
Simone Tomasi
