Author Topic: !DAILY UPDATES! September. 366 days: your 2016 in photographs  (Read 80532 times)
Re: !DAILY UPDATES! September. 366 days: your 2016 in photographs
« Reply #285 on: September 22, 2016, 23:39:54 »
I took so many pictures today but I am too tired to even browse them. Good night.
« Reply #286 on: September 23, 2016, 10:32:06 »
I dare something and post a picture totally unpumped in natural contrast and color:
RFC
« Reply #287 on: September 23, 2016, 10:35:17 »
and here is a pretty standard edit, more or less what you would expect today:
RFC
« Reply #288 on: September 23, 2016, 14:19:12 »
September 23rd  Sunny, will be a warm weekend.
Well Frank, unpumped and natural should not be too difficult.  ;) This is a completely unedited RAW from the Df.  Resized in Bicubic - Smooth gradients  to 1200.
The second one is edited to my liking ( at the moment)
« Reply #289 on: September 23, 2016, 14:23:04 »
Frank and John, which Picture Control do you use?  I use "Flat" and with the sharpening set to "zero".
« Reply #290 on: September 23, 2016, 14:29:15 »
Picture control, Akira?  That's the in-camera setting for jpg's, not?  I took directly the NEF and loaded it into ACR 16 bit- (all settings to 0) and resized in CC.
« Reply #291 on: September 23, 2016, 14:39:22 »
John, if I understand correctly, the NEF itself is not affected by the Picture Control settings, but ACR will open and display the NEF according to the Picture Control settings.
« Reply #292 on: September 23, 2016, 14:54:01 »
I just found that my ACR has been set to "Adobe Standard" in the "Camera Profile" pull-down menu under the camera icon tab.
What is your settings in your camera and in ACR?
« Reply #293 on: September 23, 2016, 15:04:19 »
No, not really. That's actually impossible in ACR. It's probably overwritten by the camera-profile, I guess.    Anyway, in-camera Profile I just have the Standard and sharpening set at 9.
« Reply #294 on: September 23, 2016, 15:13:48 »
ACR has Adobe Standard, but it's overwritten with camera settings, I think.
In ACR the file opens always with Color Space: ProPhoto RGB  in 16 bits
Mike G
« Reply #295 on: September 23, 2016, 15:27:46 »
I only use ACR through Lightroom, but camera profiles certainly do affect raw files. Normally when I import raw files recently in my case Fuji RAF files the camera profile is set to Adobe Standard! When I change to Provia Standard there is definitely a change on screen!
It has been quite a while since I imported an NEF file! so I can't remember how they were affected.
« Reply #296 on: September 23, 2016, 15:30:44 »
My NEF file seems to be opened under Adobe Standard, regardless of the camera setting, which I never noticed!
I think Mike is experiencing the same behavior of ACR...
« Reply #297 on: September 23, 2016, 15:36:09 »
Yes, so ACR opens neutrally without any In-Camera profiles, as it should.  A Raw file cannot have any pre-settings which just apply to view in the camera.
Mike G
« Reply #298 on: September 23, 2016, 16:19:10 »
Akira that is right, I haven't found a setting to open a file(s) using a camera setting so I have to change the profile whilst editing! Of course an in camera profile will only affect a jpeg file!
Just have to remember to change it while in edit mode!
« Reply #299 on: September 23, 2016, 16:26:16 »
Okay solved :)
A young yellow leaf of the lime tree (Linden)
