Author Topic: Nikkor 6mm 2.8 Ai  (Read 103252 times)
Re: Nikkor 6mm 2.8 Ai
« Reply #105 on: April 22, 2016, 15:22:16 »
Here are two more images with the 6mm from my garden - The lens is in bad need of cleaning - Not ideal for a Fisheye at all
I didn't notice inside the store but it's quite clearly visible outside when you look into the lens and from images when stopping the lens down.....
First with the vertical tripod
_EGL1888 by Erik Gunst Lund, on Flickr
Next with off-center tripod
_EGL1918 by Erik Gunst Lund, on Flickr
« Reply #106 on: April 22, 2016, 15:24:34 »
WOW WOW WOW  8)
« Reply #107 on: April 22, 2016, 15:31:13 »
looks good
« Reply #108 on: April 22, 2016, 15:33:04 »
Thanks Jakov and Frank
Here two freids working in the basement - New showers and toilets
The Vertical tripodbase is so easy and fun to use :)
_EGL1883 by Erik Gunst Lund, on Flickr
« Reply #109 on: April 22, 2016, 15:34:37 »
For the pretty extravagant asking price of a half million DKK, a spring cleaning ought to be included. ...
Erik, your tripod solutions do seem to work flawlessly. Am I surprised? Not really.
Looking forward to shooting this lens in IR etc.
« Reply #110 on: April 22, 2016, 15:49:58 »
Thanks Bjørn :)
Front element needs to come off,,,
« Reply #111 on: April 22, 2016, 16:12:02 »
Big lens => big front element => big man => no problems.
« Reply #112 on: April 22, 2016, 16:30:11 »
Don't tell me that you are going to open it up?!?!
« Reply #113 on: April 22, 2016, 16:31:03 »
Erik, these are awesome!
I observe an interesting arc-shape ghost at the right bottom of the second image.   ;)
Where were you when you took this picture?   :o
« Reply #114 on: April 22, 2016, 18:51:27 »
Will not take it apart, don't worry Jakov ;)
It has a lot of flare in all sorts of ways;) Keeping the sunrays under control is challenging so I just let it happen more or less ;)
I got the radio remote for the D810 so I'm behind tha wall ;)
« Reply #115 on: April 22, 2016, 18:54:50 »
Very impressive, Erik !!
RonVol
« Reply #116 on: April 22, 2016, 22:18:40 »
Really, really nice work Erik.
Nice job with the mounting plate too..............I have a machine-shop (gear cutting) so I know quality workmanship when I see it  ;)
« Reply #117 on: April 22, 2016, 23:39:08 »
Thanks Ron ;)
Here is the Vertical base mounted under the 6mm - I had to trim down one of the rods since the D810 Camera body is a bit larger than the old film cameras
Nikkor Fisheye 6mm Vertical base by Erik Gunst Lund, on Flickr
Nikkor Fisheye 6mm Vertical base on Gitzo Series 5
L1043808 by Erik Gunst Lund, on Flickr
Nikkor Fisheye 6mm lateral arm Gitzo Series 5 Burzynski Ball head
L1043811 by Erik Gunst Lund, on Flickr
« Reply #118 on: April 23, 2016, 00:12:49 »
Awesome, simply awesome...
The last setup looks like a cyber dog.   :o
Ah, yes, that makes sense.
« Reply #119 on: April 23, 2016, 00:18:07 »
Not the easiest lens to play hide-and-seek with ... 220 degrees out of 360 are being watched.
