Author Topic: Nikkor 6mm 2.8 Ai  (Read 103369 times)
Re: Nikkor 6mm 2.8 Ai
« Reply #75 on: March 23, 2016, 10:42:57 »
Thanks Jørgen! ;) I hope I'm not boring people to death with my project  ::)
Here are some sketches of the support:
Off-centre Tripod
6mm Tripod Vertical base and Video relay support by Erik Gunst Lund, on Flickr
Vertical Base
The Vertical base on tripod, for full view of rear camera display
Untitled by Erik Gunst Lund, on Flickr
And the two combined for Video relay lens stack
« Reply #76 on: March 23, 2016, 10:45:26 »
Kudos to the invention and also the artist who drew the sketches.
I love the bow tie on the photographer  8)
« Reply #77 on: March 23, 2016, 10:46:59 »
 ;D 8)
« Reply #78 on: March 23, 2016, 10:56:34 »
I was about to ask the same question about the bow tie - hope you do have one of these, Erik?
stenrasmussen
« Reply #79 on: March 23, 2016, 11:03:37 »
I like the oily hair style. Have you been to the coiffeur Erik?
« Reply #80 on: March 23, 2016, 11:09:41 »
With 220 degrees field of view the tie and loose hair will all to easily get into the frame - Hence the bow tie and grease   ;D
« Reply #81 on: March 23, 2016, 11:30:59 »
A pair of Pocket Wizards can be a substitute for the bow tie and the greased hair, but what about the dancing shoes?
« Reply #82 on: March 23, 2016, 12:56:55 »
Jakov, Kudos well earned I'd say.
Actually the sketches are helpful to an onlooker such as myself for they show quite nicely the challenges that a 220 degree field of view pose for the photographer and how they will be dealt with in this instance.
Nice work Erik and an excellent preparation.
I just hope that the weather and light will be kind to all of  the Killin group and that in due course we get to see this rare lens performing to its fullest.
Almass
« Reply #83 on: March 23, 2016, 13:07:36 »
The Doctor at work  8)
« Reply #84 on: March 23, 2016, 13:31:32 »
 ;D ;D 8)
« Reply #85 on: March 23, 2016, 14:07:52 »
BTW There is a much easier fix than the 'safety ring'
It is to drill one or two holes and cut threads in the collar and through the ring.
I already have a screw like this in my Burzynski Ball Head adapter ring - Series 3-4 to Series 5 - so I don't loose the ring,,,
Erik, if you have a drilling machine, it should be easy to make it safer that way.
I don't think it is urban myth.  By Gitzo design, the bolt tighten the ring below the lower edge of the plate.  So, the more you tighten the bolt, the more the upper part of the ring will be open.  As a result, the ring is hold at the lower edge of the plate.
I replaced the central hub of my Gitzo Series 3 Systematic with the alternative hub made by Markins (TH-300).  So, the problem is gone forever.
Sorry for the deviation.  Let's go back to the original topic!  :)
« Reply #86 on: March 23, 2016, 16:50:15 »
Yes this is true for the Series 3/4 - of course dependent on the depth of the plate this could be an issue,,, But this is not the case for a Series 5 where the bolt is located at the edge, not below, and when you tighten you can actually measure the collar getting smaller in diameter 0.2mm - closing at the top, not opening!
« Reply #87 on: March 23, 2016, 19:22:26 »
Oh, I see.  I will look closely when I have a chance to see a Series 5 one.  Thanks for the detailed explanation!
« Reply #88 on: March 23, 2016, 20:13:25 »
No problem ;) Thanks for the heads up Akira! For glass like this I will not take any chances,,,
« Reply #89 on: March 23, 2016, 21:02:51 »
You are welcome, Erik!
