Author Topic: My first lens dissembly, tips?  (Read 22994 times)
Re: My first lens dissembly, tips?
« Reply #15 on: March 08, 2016, 05:15:52 »
« Reply #16 on: March 08, 2016, 05:19:22 »
jesus! what a close up!  :o :o :o
it might be just a set screw (-) with the slot painted over with paint. Nikon uses paint to cover up the set screws. you can try and carefully scratch the surface and see if it is indeed a (-) set screw.
« Reply #17 on: March 08, 2016, 05:25:08 »
I looks like the screwhead is on the inside actually.  You can see that the helicoid is not accessible, and I see no way to remove it  :-\
« Reply #18 on: March 08, 2016, 05:29:31 »
well, for something like that, the screws are probably under that rubber grip  :o :o :o
have you read my tear-downs? this lens should have a lot in common with the 85mm and 55mm that i posted in my blog.
« Reply #19 on: March 08, 2016, 05:37:06 »
I removed the rubber grip and there is a strip of tape running around the barrel under it.  Is this safe to remove and does it need to be replaced?
« Reply #20 on: March 08, 2016, 05:40:37 »
Good Luck, man.
« Reply #21 on: March 08, 2016, 05:48:49 »
I cut a small area of tape out to access the screw and it is indeed a set screw.  What tool do I need for this?
« Reply #22 on: March 08, 2016, 06:45:52 »
that tape is for aligning the infinity mark  :o :o :o
if you look at my repair notes you will see that nikon loves using scotch tape for this part  ::)
always remember to mark anything before you separate them!
« Reply #23 on: March 08, 2016, 06:57:49 »
Thanks.  What tool do I use for the set screw?
« Reply #24 on: March 08, 2016, 07:03:21 »
just a small precision screwdriver.  :o :o :o
be careful. they can be fragile
« Reply #25 on: March 08, 2016, 07:06:58 »
Yeah, their fragility surprised me.  I already stripped two screws.  Luckily they turned out to be screws I do not need to remove for this job, but I already screwed myself for the future, not feeling very good.  :-\
« Reply #26 on: March 08, 2016, 07:09:51 »
have you tried reading the first few posts in my blog? they pretty much cover these things because i have been in the same mess and i dont want anybody to destgroy their lens because of that  :o :o :o
« Reply #27 on: March 08, 2016, 07:18:07 »
Didn't see those posts until now.
« Reply #28 on: March 08, 2016, 07:23:29 »
i am going to buy some set screws this or next month. if you ruined one, i can probably give you a replacement  :o :o :o
« Reply #29 on: March 08, 2016, 07:34:22 »
I didn't ruin the set screw as I do not currently have a tool to remove it.  I stripped one of the two screws that holds the aperature ring on, and one of the side facing mount screws.
