Author Topic: My first lens dissembly, tips?  (Read 22947 times)
Re: My first lens dissembly, tips?
« Reply #45 on: March 09, 2016, 04:25:53 »
Based on the 85/1.4 Ais and 135/2 Ais that I have partially disassembled, the scotch tape can be removed no problem.  Make sure you have fresh tape on hand to replace it when you reassemble. I used the tough Scotch Package Sealing Tape.  Use magnified live view to re-calibrate infinity focus.  Remember that for a normal or tele lens, Infinity = 3 miles, 5 miles away, not across the street.
As an alternative to buying[and waiting for delivery of] new screwdrivers, you can file down an existing screwdriver.  I have many "junk" so-called jeweler's screwdrivers that I can sacrifice.  Those small slot screws need a very close fit as much as the cross headed screws need the exact fit of JIS screwdrivers.
« Reply #46 on: March 09, 2016, 04:44:58 »
Regarding the tape, do I need to remove it to get to the helicoid inside the focus ring?  I'd rather not unless necessary.  Of course, i do not know how to gain access to this helicoid, which is my current problem.
As for the screwdriver, I'd like to just purchase one that fits as i don't want to chance stripping such a tiny and buried screw.  Hoping someone knows, otherwise I'm gonna order a 1.5mm and give it a whirl.
« Reply #47 on: March 09, 2016, 04:50:14 »
you can safely remove that.
read this to see how and what the tape is used for :o :o :o
http://richardhaw.com/2016/01/30/project-zoom-nikkor-80-200mm-f4-ai-s/
« Reply #48 on: March 09, 2016, 04:59:24 »
So it is only covering the shims?  Ok.  I ordered a 1.5mm and a 1.2mm slot screwdriver from micro-tools and will give it a go as soon as they arrive.  I'll let you guys know which worked best.
Not looking forward to getting the helicoids together!  :P
« Reply #49 on: March 09, 2016, 05:38:54 »
its just to keep the focusing ring together.  :o :o :o
dont lose hope. if i did it with the 200mm f/4 Ai-s on my first try then you can do it as well
« Reply #50 on: March 09, 2016, 05:41:24 »
I find that pretty shocking that only scotch tape holds them together.  i wondered what the screw I just ordered screwdrivers is for.
« Reply #51 on: March 09, 2016, 05:58:07 »
Don't use the milky white Scotch tape, its so slippery that the rubber focus ring slips instead of focussing the lens  :o :o :o
Good luck btw, been there with the helicoids and it can become frustrating.
Just grap a beer to calm the nerves and stabilise the hands  8)
« Reply #52 on: March 09, 2016, 06:13:12 »
Thanks Jan.  The 105mm being one of the only two lenses I own, it is quite the nervous situation!  A beer will come in handy.   :)
« Reply #53 on: March 09, 2016, 06:29:00 »
did you take pictures of the helicoid before you separate it?  :o :o :o
« Reply #54 on: March 09, 2016, 06:33:01 »
No, I had no idea they could be put together in several incorrect manners.  I have accepted the hours of trial and error to come.  ::)  Live and learn.  I think that when I do get it right, I will make sure to make a small nick in the paint for the future.
« Reply #55 on: March 09, 2016, 06:47:24 »
did you watch the video that i posted on page 1? i watched it again and it is all that you need to get that thing back together.  :o :o :o
« Reply #56 on: March 09, 2016, 06:51:53 »
I did not.  I obviously should have done more preparation instead of diving in blind.  Too cocky I guess.  :P  I will certainly be going through your blog while I wait on the screwdrivers.  Many thanks Richard, I owe you!
« Reply #57 on: March 09, 2016, 06:53:36 »
daitocamera's video is in Japanese but even with the audio off you can still pick up what he is trying to do  :o :o :o
« Reply #58 on: March 09, 2016, 06:57:13 »
Oh . . . my.  I somehow missed that link, at first I thought you meant on the first page of your blog . . . have you ever looked around for something you "couldn't find", only to realize it was in your hand while you searched . . . that's me right now! :-[
« Reply #59 on: March 09, 2016, 07:09:33 »
Well, good and bad news.  i decided to take the tape off, and it exposed the helicoid I was trying to get to!  Bad part, is did not thinking of making a measurement with my caliper before doing so.  Which I should have.  There is no shim however, so I am hoping the two parts simply fit snug.
