Author Topic: Nikon D5  (Read 121774 times)
Re: Nikon D5
« Reply #180 on: January 08, 2016, 00:58:43 »
https://photographylife.com/what-you-need-to-know-about-the-new-nikon-d500
this is where I found it.
I post this as an extra reply because my smartphone clipboard
deletes everything I wrote if I insert the clipboard.
thx Frank.
Re: Nikon D5
« Reply #181 on: January 08, 2016, 02:23:05 »
interesting.. http://imaging.nikon.com/lineup/dslr/d5/spec.htm
Approximate frame advance rate   Up to 10 fps (CL); 10 to 12 fps, or 14 fps with mirror up (CH); or 3 fps (quiet continuous mode)
so they don't guarantee 12fps... (10-12fps)
Re: Nikon D5
« Reply #182 on: January 08, 2016, 02:33:30 »
Will depend on shutter speed.
I ran the D5 with 12fps and had no issues.
Re: Nikon D5
« Reply #183 on: January 08, 2016, 02:47:36 »
how did you measure it?
Re: Nikon D5
« Reply #184 on: January 08, 2016, 03:51:08 »
Using "photographic memory".  :D
MILLIREHM
  • Vienna, Austria
Re: Nikon D5
« Reply #185 on: January 08, 2016, 08:01:56 »
I doubt the value of 14fps with mirror up
Wolfgang Rehm
PedroS
Re: Nikon D5
« Reply #186 on: January 08, 2016, 09:06:37 »
It's fairly easy to measure it...
A stopwatch and counting the frames taken...
Re: Nikon D5
« Reply #187 on: January 08, 2016, 09:34:56 »
"I doubt the value of 14fps with mirror up"
My AW1 does 60 frames per sec. in raw, so why not?
Seapy
Re: Nikon D5
« Reply #188 on: January 08, 2016, 09:57:18 »
Look at the EXIF??? The times of the exposures should tally over say, 10 seconds, 120 images. I would have thought...
Robert C. P.
South Cumbria, UK
Re: Nikon D5
« Reply #189 on: January 08, 2016, 10:18:50 »
The software based shake reduction is for video only since video files have lower resolution than the native image of the sensor, and so there are extra pixels that can be used to estimate the shake trajectory, reduce it in software and finally store resample it to the video resolution and store in the video files.
Likely the maximum fps rate depends on the lens and perhaps the aperture as well. With the aperture mechanisms of G lenses in the longest lenses I suspect the maximum rate is a bit less than specified, while with the E lenses it should reach the nominal rate if the shutter speed is fast enough. In this article
https://photographylife.com/reviews/nikon-500mm-f4e-vr/3
the author notes getting 10fps from the 500/4G vs. 11fps on the 500/4E with the D4s at f/4 to f/16, 10.5fps at f/22. I suspect the high fps is possible with short G lenses with shorter mechanical connections between the camera and the aperture blades.
On the other hand I've had some struggles with E lenses in the cold. I was shooting landscape on the sea coast and it was about -23 C to -19 C depending on the day.  The sea was still open for the most part and there was a lot of "sea smoke". After a while of using the D810 and 24 PC-E I got Err and the aperture seemed to behave erratically. Some shots were wildly overexposured. I noticed in live view that as I opened up the aperture, the image went dark! It could be some communication problem with the body and lens.  The camera also refused to operate in M-UP mode, reverting to S behavior.  I've not seen this particular problem before and it went away after the body and lens were warm again. I'm just saying that while the E aperture control is helpful there may be still some glitches with the implementation.  I've had problems in the past using the D800 and D700 locking up (with different symptoms) in similar conditions and usually I've been using a PC-E lens in those cases though I can't remember if it the lens was always an E lens. I would have to check old files.
stenrasmussen
Re: Nikon D5
« Reply #190 on: January 08, 2016, 10:23:17 »
Why?
Re: Nikon D5
« Reply #191 on: January 08, 2016, 10:24:59 »
It's also a feature that has been available in smartphones for years.
Re: Nikon D5
« Reply #192 on: January 08, 2016, 10:27:48 »
yes you could read the time between recorded images..
duh.. sorry
Re: Nikon D5
« Reply #193 on: January 08, 2016, 10:49:18 »
EXIF Data show seconds in time stamp. If you see 12 exposures for several seconds ....
Re: Nikon D5
« Reply #194 on: January 08, 2016, 10:56:57 »
yes, yes, yes.. thx for the help
