Author Topic: Nikon D5  (Read 119643 times)
Re: Nikon D5
« Reply #165 on: January 07, 2016, 17:33:14 »
Yes, the "end" is still the same so you can put the rubber eyecup on igt. Or a right angle finder.
so the adapter is presumably to seal the pentaprism from dust, etc... ???.   not sure why it needs to be removed.. maybe for the right-angle finder?
Eddie Draaisma
Re: Nikon D5
« Reply #166 on: January 07, 2016, 17:47:20 »
The clue is in the D5 brochure:
"The D5 employs the detachable DK-27 Eyepiece Adapter, which helps quick attachment of a rain cover. Prepare another DK-27 and have it attached to a rain cover in advance. If rain suddenly starts, you can quickly cover your camera with it, just like changing the eyepiece adapter, so you won't miss any photogenic moments."
Re: Nikon D5
« Reply #167 on: January 07, 2016, 18:00:46 »
Or, maybe you can attach an L-angle finder to another DK-27 to attach/detach conveniently...
Re: Nikon D5
« Reply #168 on: January 07, 2016, 19:25:14 »
"you won't miss any photogenic moments"
Advertising writing taken to another level :D
In practice, though, you'll lose many of those moments "photogenic" or not, as removing/inserting the DK-27 is pretty awkward unless your fingers are small and nimble. We were several who tried and all fumbled a lot.
Re: Nikon D5
« Reply #169 on: January 07, 2016, 20:49:54 »
i have a raincoat suitable for the camera and big glass.. i won't be using this feature let me tell you.. hardly makes design/cost sense to me.. must have been something else.  curious..
i am really contemplating waiting for the D5s  -  since i own a D4s + D810 + D800E.... i was hoping for the 15fps, so for less than 10% frame rate improvement and 20Mpx which if you take the square root amounts to also less than 12% over the D4s vs improved ISO and AF... by the way, wildlife really has me using 9-pt center so the fancy 3-D moving around is kinda wasted on me..  so the AF is marginal as well... then i purchased the XQD cards only to now have to choose between the two (i actually got used to one of each since i used CF in my other cams)... well this starting to sound like a rant..
i am on the fence.
BW
    • Børge Wahl-Photography
Re: Nikon D5
« Reply #170 on: January 07, 2016, 22:32:15 »
Actually, I was just out to check. My D4s still work even if the D5 was announced ;) Even in minus 18 degrees celsius.
MILLIREHM
  • Vienna, Austria
Re: Nikon D5
« Reply #171 on: January 07, 2016, 22:51:00 »
Not a big surprise (not nearly as the D500). The Olympics year and the D5 as a evolutionary minor step development of the D-Series.
An advanced AF system with more AF-points and 4k Video as the main steps compared to the D4s
Similar to Bob no reason for a D4S user to upgrade. I bought one last year and I think I will continue to be very satisfied with it for a significant amount of time
Maybe until the D6 or so ;-)
Wolfgang Rehm
Re: Nikon D5
« Reply #172 on: January 07, 2016, 22:59:01 »
damn...that looks like me on the rock :)
very nice shot by the way!
BW
Re: Nikon D5
« Reply #173 on: January 07, 2016, 23:08:34 »
Some of the advantages with the new announcements are discussed at dpreview http://www.dpreview.com/opinions/7352408758/nikon-s-new-d5-and-d500-push-the-boundaries-of-dslr
The disproportionate look of the 14-24 suits my rather poorly, Bob ::)
Re: Nikon D5
« Reply #174 on: January 07, 2016, 23:16:32 »
interesting... i somehow missed that the D500 has in-camera VR..
Re: Nikon D5
« Reply #175 on: January 08, 2016, 00:02:31 »
I understood it is only for video. Did I miss something?
Re: Nikon D5
« Reply #176 on: January 08, 2016, 00:15:04 »
ok.. i really don't know to tell you the truth.. i guess so.. but i don't know why it would only be video.
Re: Nikon D5
« Reply #177 on: January 08, 2016, 00:19:26 »
Ill check back tomorrow. Too tired now.
Re: Nikon D5
« Reply #178 on: January 08, 2016, 00:30:37 »
6) Electronic VR for Shooting HD Video
While the Nikon D500 does not have in-body image stabilization (IBIS), Nikon developed something called “Electronic Vibration Reduction”, which basically stabilizes video shooting via software. And the cool thing is, you can actually use this feature in combination with lens VR to get even better results! Nikon made this electronic VR work in 3 directions – horizontal, vertical and rotational.
Re: Nikon D5
« Reply #179 on: January 08, 2016, 00:33:03 »
https://photographylife.com/what-you-need-to-know-about-the-new-nikon-d500
this is where I found it.
I post this as an extra reply because my smartphone clipboard
deletes everything I wrote if I insert the clipboard.
