Author Topic: [Theme] Show us your best moon (and solar system) images  (Read 250565 times)
Nasos Kosmas
  • Athens, Greece
« Reply #660 on: February 27, 2021, 21:12:39 »
 I can’t stand shooting moon :)
This time a full crop  frame Nikon 200-500  on 500mm plus TC 2X IIIe on z50
I was amazed by the combination with good IQ results, excellent VR handheld and autofocus on f11!-even in low light
« Reply #661 on: March 13, 2021, 11:37:04 »
Scanning old files
France
August 4, 2007
D50, 18-200mm f/3.5-5.6vr
« Reply #662 on: March 13, 2021, 20:37:35 »
Scanning old files
France
August 4, 2007
Brilliant! I'd crop it in a bit though.
« Reply #663 on: March 14, 2021, 08:30:34 »
Thanks Hans, yeah cropping is an option ;)
  • Fairbanks, Alaska
« Reply #664 on: March 14, 2021, 09:57:28 »
Yes cropping might improve it, original take on the moon. What is the white dot on top of the paraglider?
mxbianco
« Reply #665 on: March 14, 2021, 10:36:18 »
Possibly the small parachute causing the opening of the main parachute. The looks are not of a paraglider (parapente in french, parapendio in italian), not wide enough to take off a hill, you jump off a plane, helicopter, balloon, whatever.
Ciao from Massimo
« Reply #666 on: March 14, 2021, 11:10:43 »
Thanks for the comments, i cant remember anything of the situation here its 14 years ago, the d50 was my first digital dslr and the 18-200mm a sort of all purpose lens, this was shot at 200mm, at short range it was quite acceptable, but distance shot maybe adequate? Then this kinda shot is a chance situation which must be my general style  ;).
mxbianco
« Reply #667 on: March 18, 2021, 12:55:54 »
Solar eclipse at sunrise, Jan 04, 2011 08:04:47
While watching my image database, came across this one... the beginning of the eclipse.
Ciao from Massimo
  • Fairbanks, Alaska
« Reply #668 on: March 19, 2021, 06:57:59 »
Very Nice Massimo!
Just to follow up on the same line, here is one I might have posted in another thread before from the 2016 March 8 partial eclipse. I was very happy to capture it as we were right at the limit here in Fairbanks and it occurred just as the sun was setting so I was not sure it would be above horizon.
(Captured with the 300mm f/4 PF on the AW1. A Baader solar film based filter was used for the capture, which is about neutral - the color was not added but is the natural one at sunset with daylight white balance.)
« Reply #669 on: March 19, 2021, 11:16:45 »
Ciao from Massimo
Very Nice Massimo!
Man, you guys are too good!
« Reply #670 on: March 19, 2021, 11:26:36 »
Wow those are amazing!
« Reply #671 on: March 19, 2021, 12:15:06 »
Yes, stunning images!
Thomas Stellwag
« Reply #672 on: March 19, 2021, 13:18:49 »
yes - superb images are shown here - congrats
Thomas Stellwag
« Reply #673 on: March 19, 2021, 15:22:36 »
wow with the Eclipse images !
Fons, I also owned the 18-200 and used it with a D40 and then a D300
Initially is like a dream, then you get to know more about lenses
mxbianco
« Reply #674 on: March 19, 2021, 17:56:12 »
Very Nice Massimo!
There's a perfect duality in the two images: in mine, the sun is going up and catching up on the moon (upper R); in yours, the sun is going down and the moon is on lower L side.
Regarding the sun's size, I used a D300 + 300 mm/4 too (the old AF-D screwdriver type, manually focused), I didn't use any filter (had none at the time), but I had to resort to 1/6400 @f:8.
On your image the sun is bigger because the AW1 sensor is a little smaller than the D300's (DX).
Thanks everyone for the kind comments!
Ciao from Massimo
