Author Topic: [Theme] Show us your best moon (and solar system) images  (Read 349456 times)
mxbianco
« Reply #675 on: March 19, 2021, 20:04:11 »
Can't get any thinner
This one is from June 2020
Nikon 1V1 + FT-1 + 70-300mm f/4.5-6.3G AF-P DX VR IF-ED zoom-Nikkor
The V1, though being a 2011 project, works with AFP lenses (and does AF and VR, too).
Ciao from Massimo
« Reply #676 on: March 19, 2021, 23:47:57 »
Lovely subtle arrangement here Massimo.
  I also enjoy the dual eclipse post!
« Reply #677 on: March 20, 2021, 09:28:38 »
Thanks for the very fitting dual eclipse comment Massimo and everybody else for the enthusiastic comments.
WGHalvorsen
« Reply #678 on: March 21, 2021, 10:57:01 »
Here is a shot with an Oly E-M1x with 300mm F4 Pro and x2 TC.
mxbianco
« Reply #679 on: March 21, 2021, 14:23:59 »
Lots of detail in this one! Very effective slicing illumination, gives depth to the craters.
Here's a casual plane trajectory which intercepted the moon and then changed course.
I didn't edit out the roof corner, as the plane looked like heading for it in its awkward course...
The next minute, the moon had already moved out of the trailing path of the plane.
Like the other antenna picture, I waited for the good moment when the moon would be at the right place, with the plane still within the frame.
Nikon D5300 + Nikkor 18-55mm 3.5~5.6 AFS-VR DX @20mm. Sunset, Nov 18, 2020
Ciao from Massimo
« Reply #680 on: March 21, 2021, 18:49:51 »
Looks like it aimed for the moon, and then continued on its course!
mxbianco
« Reply #681 on: March 21, 2021, 21:03:49 »
That's exactly what I was trying to make it happen!
Actually the plane had already passed, leaving its trail, and the moon (moving L to R) caught up on the plane trail just in time! Probably not a commercial flight...
Ciao from Massimo
mxbianco
« Reply #682 on: March 27, 2021, 07:53:09 »
Bump on the tripod
While taking a sequence of the moon, a little bump on the tripod had this little effect... This is what happens at 1/40" with just a little bump: a moon tube!
Ciao from Massimo
« Reply #683 on: March 27, 2021, 09:26:11 »
Bump on the tripod
Ciao from Massimo
Great moon trail!
Imagelover
  • Teacher to minority speaking people in Norway
« Reply #684 on: March 28, 2021, 15:16:55 »
Nikon D810 and the Reflex-Nikkor 1000mm f/11.
One picture taken is far better than none!
« Reply #685 on: March 28, 2021, 20:29:25 »
This is spectacular!
« Reply #686 on: March 29, 2021, 12:56:28 »
Moon and temple.  Shot with K Nikkor 400/5.6@f11.
Imagelover
« Reply #687 on: March 29, 2021, 20:39:50 »
Thanks, Akira! Your's great too!
« Reply #688 on: March 29, 2021, 22:48:30 »
Thank you!
Bob Foster
« Reply #689 on: March 30, 2021, 00:57:05 »
From last evening. This is the first photo of the moon I've made.
D850 500 f4D IF ED + TC-14E II. Raw conversion and basic adjustments were done with Photo Ninja, then the image was tweaked in Capture One, run through Topaz Sharpen AI (sharpening backed off to less than 1/3 of the "recommended" value, and noise suppression  set to over 5 times the "recommendation." The "improvement" due to use of Topaz Sharpen AI is, in this instance, very modest.
