Author Topic: Interesting test of the Noct-Nikkor 58/1.2 Ai-S  (Read 9848 times)
stenrasmussen
« on: August 27, 2015, 12:22:34 »
With actual measurements too. Apart from its CA department not bad at all.
https://photographylife.com/reviews/nikon-noct-nikkor-58mm-f1-2#more-116770
Re: Interesting test of the Noct-Nikkor 58/1.2 Ai-S
« Reply #1 on: August 27, 2015, 12:42:48 »
The stats show the noct beats the 58g by an ample margin in sharpness i but once had the occasion to shoot with the noct, cheapest copy in the market is some €2500 at least.
« Reply #2 on: August 27, 2015, 12:45:55 »
Sten, many thanks.  With rarity and price I think I will have to be happy with the 58 1.4G (which I am  :) ) .  I can always dream of finding one in some out of the way shop where the owner doesn't know what he has .. lol
Tom
« Reply #3 on: August 27, 2015, 13:32:23 »
Thanks for finding and sharing Sten.
The test seems to differ a lot from this one:
http://www.photozone.de/nikon_ff/883-nikkorafs5814ff?start=1
Re shrapness values overall and sharpness values for mid and corener are much more even. But I don't know how they measure preciesly or why there is such a huge difference.
I don't really see that much difference between the old Noct Nikkor and the new 58mm 1.4... Except maybe the old Noct had more of an even field curvature...
« Reply #4 on: August 27, 2015, 14:34:58 »
Do I understand correctly that peak performance at f=4 is due to
sensor characteristics of the D810 and that peak performance might
be found at f=5.6 for a D600 or F=8 for a D3?
« Reply #5 on: August 27, 2015, 14:53:16 »
No, I belive that is a wrong assumption.
« Reply #6 on: August 27, 2015, 15:52:27 »
I thought the Diffraction limit of the sensors do override the
resolution limit of the lens which might well be at f=4.
So if it was at f=5.6 the smaller pixels might see the peak at f=4
anyway.
As discussed earlier the absolute value of a higher res Sensor
will still be higher than that of a lower res sensor at same aperture.
simsurace
« Reply #7 on: August 27, 2015, 16:54:19 »
anyway.
I'm positive that we have debated this at length in the past. The only way for a sensor to shift the peak of the resolution curve (as a function of aperture), is for the sensor-only MTF function to depend on the aperture of the lens. If you're willing to assume this, you can end up with a peak at f/4 with camera A and a peak at f/5.6 with camera B. Personally, I think the assumption is very unrealistic, plus I have never seen measurements which would lead me to conclude that it is needed. For all intents and purposes, the sharpest aperture of a lens is the same over a very wide range of sensors. Higher-res sensors are therefore expected to give a boost (however small) in resolution at all apertures, and we do not expect the existence of a "diffraction-limited" aperture beyond which there is no resolution increase whatsoever (leaving aside the effects of focusing errors and camera shake which may mask small gains in resolution).
Simone Carlo Surace
suracephoto.com
Almass
« Reply #8 on: August 27, 2015, 17:48:47 »
What is there to compare?
One is a night and stars lens and the other is a portrait lens.
One is a collector item and the other is an artsy/fartsy item.
One is manual and the other is AF.
I have both and don't use either. I got the Noct for my collection many years ago and got the 58G because there was a special offer this summer at J. Lewis for GBP999 less VAT, you do the math.
For my type of work, they simply don't cut. Unfortunately, I have limited time to indulge in artsy/fartsy photography and frankly I would rather use the Leica R 50/60. It trashes all 50 focals across all brands.....and I do not do brick walls or IMA test.
« Reply #9 on: August 27, 2015, 19:14:05 »
Why would one opt for a mistress if there is a beautiful wife yearning for you at home?
These Nikkors put you in a similar, but perhaps easier solvable, quandry.
Enjoy both. Or stick to the one you have available. Or dream on.
(killing a couple of waiting hours at Frankfurt International enroute to S.A.)
« Reply #10 on: August 27, 2015, 19:44:07 »
As Paul Newman would say: "Why fool around with hamburger when you have steak at home?”
45P rules 8)
« Reply #11 on: August 27, 2015, 19:54:51 »
The 45 P is nice enough, but it lacks the magic of the Noct. Besides, it's way too tiny for my hands.
« Reply #12 on: August 27, 2015, 20:08:58 »
Get on that plane!  ::)
There are probably dozens of great normal lenses out there (45-60mm). Probably the most of all focal lengths...
« Reply #13 on: August 27, 2015, 22:39:04 »
Did I mention? I like the 1.8/50g .... hahahah
Thank you Simone. Convincing argument!
« Reply #14 on: August 28, 2015, 07:57:02 »
If I remember correctly, the aspherical surface is the front side of the second element, not the first one.
EDIT: my memory betrayed me.  The review is correct.
