Author Topic: June 2024  (Read 73582 times)
Re: June 2024
« Reply #15 on: June 02, 2024, 19:06:33 »
I missed a couple of days....Nikongear is in full swing. Thank you all for the stories and images you so generously share.
Re: June 2024
« Reply #16 on: June 02, 2024, 19:09:12 »
Meet Naza,
  BIF (bellerina in flight) is actually from may the 30th, taken with Z6 and 58mm 1.4G I missed Birna´s Z9. There is a considerable shutter lag with my older model. I have to readjust after shooting with other cameras.
  The hole batch was worked on alien skin exposure 5 because nikon´s capture NX-D keeps on crashing on me for no apparent reason since the last software update. I have downloaded the latest NX-D version and it keeps on crashing....on the meantime, Exposure 5 is a pleasure to use.
Ian Watson
Re: June 2024
« Reply #17 on: June 03, 2024, 16:16:52 »
There is something soulless about large airports. This is Terminal 3 at Toronto Pearson.
Nikon Zf, 50mm f/1.4 AI.
Re: June 2024
« Reply #18 on: June 03, 2024, 16:24:47 »
The green grass
D850 AF-D 200/4
Dogman
Re: June 2024
« Reply #19 on: June 03, 2024, 16:30:13 »
Here's Christie again--my favorite model.  This was just after brushing her coat so she was looking at her best.  For about 10 seconds.  She immediately went to her favorite chair and proceeded to muss up her hair to her satisfaction.  She always seems to attract the best light so I had to capture it.  D700, 50/1.8 AI-S "long nose" Nikkor.  A little help here from Lightroom and Silver Efex Pro3.  Even Christie can use some post processing.
Re: June 2024
« Reply #20 on: June 03, 2024, 17:38:25 »
Airports are like burgers: all the same, just more or less stale. I just arrived at Oslo Gardermoen, and that one is quite fresh.
Not for photography, but for business, alas. There are worse places for sure. Having a burger, precisely, at Fjøla (at Oslo station).
Re: June 2024
« Reply #21 on: June 03, 2024, 21:11:35 »
June 3
Grass indeed, Calamagrostis acutiflora 'Overdam' .
Z7_2  -  Z 105mm f/2.8S
Re: June 2024
« Reply #22 on: June 03, 2024, 21:40:32 »
Object with a void.
Re: June 2024
« Reply #23 on: June 04, 2024, 00:34:44 »
The green grass
D850 AF-D 200/4
  Beautiful minimal monochromatic full of light.
Re: June 2024
« Reply #24 on: June 04, 2024, 00:36:51 »
A hug when needed.
 Z6, 70-200 2.8 fl
Re: June 2024
« Reply #25 on: June 04, 2024, 10:00:38 »
June 4
This morning' born calf with mother.
Zf  -  Z 40mm f/2
Re: June 2024
« Reply #26 on: June 04, 2024, 16:12:44 »
I'm kind of warming to the 12-28 PZ Nikkor for my Z/Dx cameras. Colour aberrations are quite well under control, sharpness is good, flare resistance likewise is good too; however there is significant barrel distortion at the very wide end. Nikon's software or in-camera generated jpgs will mitigate most of these issues.
When the end user, like me, uses non-Nikon software for processing, te barrel distortion is obvious but that won't entail it is always require digital massage in order to be of little pictorial importance.
This image from Oslo Central Station underscores that point. It is taken at 12mm setting, and due to the bending lines in the subject I didn't find it necessary to do any corretion of the barrel distortion at all.
Re: June 2024
« Reply #27 on: June 04, 2024, 16:25:20 »
Thanks Paco
Ian Watson
Re: June 2024
« Reply #28 on: June 04, 2024, 16:59:53 »
A hug when needed.
Beautifully framed and timed!
Ian Watson
Re: June 2024
« Reply #29 on: June 04, 2024, 17:03:42 »
An excellent analogy, Airy.
Manchester airport is a bit fresher than Toronto Pearson. It has a sense of humour for one thing. A caption nearby read, "It's a steal!"
Nikon Zf, 35mm f/2 AI.
