Author Topic: June 2024  (Read 73554 times)
Re: June 2024
« Reply #30 on: June 04, 2024, 23:54:01 »
Beautifully framed and timed!
 thank you Ian
Re: June 2024
« Reply #31 on: June 04, 2024, 23:55:07 »
Before the show.
  D5, 28mm 1.4e
Re: June 2024
« Reply #32 on: June 05, 2024, 10:18:07 »
June 5
Rosa
Z7_2  -  Z 105mm f/2.8S
Ian Watson
Re: June 2024
« Reply #33 on: June 05, 2024, 17:37:29 »
While coming in to land at Keflavik airport (Iceland), I had not expected to see the volcanic eruption near Grindavik in the distance. The dramatic tilt is a result of haste rather than artistic intent.
Nikon Zf, 105mm f/2.5 pre-AI.
kasperbergholt
Re: June 2024
« Reply #34 on: June 05, 2024, 17:46:22 »
Fine strands of macroalgae (seaweed) through a sun-lit surface of a small pond in the Gardens of the Royal Danish Horticultural Society.
Nikon D3 & Zeiss Milvus 50mm.
-- Kasper Bergholt
Re: June 2024
« Reply #35 on: June 05, 2024, 18:23:47 »
With the combination of high resolving power of the lens (Scanner Nikkor ED) and the high pixel count of Z9, I was able to detect nano black holes on my dinner table. A real surprise discovery  I'd like to share with the NG community.
The image has been subjected to sophisticated PRIMO processing, in order to better trace the emerging jet stream from the minute black hole :)
Luc
    • Flickr
Re: June 2024
« Reply #36 on: June 05, 2024, 21:52:25 »
Gargoyle, Amersfoort/Nederland
Nikon Z6 + Z 24-200mm
Z6_DSC4460 by Luc de Schepper, on Flickr
Re: June 2024
« Reply #37 on: June 05, 2024, 23:14:23 »
Warming up for the show.
  D5, 105mm 1.4e
Re: June 2024
« Reply #38 on: June 06, 2024, 10:06:28 »
Quote from: Ian Watson
I've wondered about this for a while Ian, given this airport is the main route in/out of Iceland.
I guess they know enough about the geology of the area plus likely prevailing winds,  to plan for any expansion of the vents.
I was able to detect nano black holes on my dinner table. A real surprise discovery  I'd like to share with the NG community....plus the emerging jet stream from the minute black hole :)
I'm both confused, and also slightly worried Birna.....
Re: June 2024
« Reply #39 on: June 06, 2024, 16:23:42 »
June 6
girl on fatbike
D850  -  28mm f/1.4E
Ian Watson
Re: June 2024
« Reply #40 on: June 06, 2024, 18:07:04 »
This oak tree is just around the corner from where I grew up. It looks as magnificent as ever.
Nikon Zf, 35mm f/2 AI.
Re: June 2024
« Reply #41 on: June 06, 2024, 18:29:11 »
I suspect you fly a lot Ian!
Re: June 2024
« Reply #42 on: June 06, 2024, 19:41:41 »
Nettles
Df  70-200/2.8E
Re: June 2024
« Reply #43 on: June 07, 2024, 07:17:30 »
High water in the pond
Fuji S5 Pro  70-200/2.8 E
Re: June 2024
« Reply #44 on: June 07, 2024, 12:42:11 »
Cannot see what's growing there, but most stuff of an aquatic nature is interesting :)
