Author Topic: Do You Prefer Rendering Of "Vintage" Nikon Cameras To "Modern" Nikon Cameras?  (Read 69474 times)
NEF is a specialised TIF file.
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
Here's a colorful shot from today using D1X and 105mm f2 DC Nikkor.
https://www.flickr.com/photos/f2guru/53577683320/in/dateposted-public/
I'm really liking the CCD colors that I get directly out of my Nikon 1DX.
BruceSD
    • The F/2 Guru
I'm quite pleased with the sharpness in this D1X image.
https://www.flickr.com/photos/f2guru/53577691420/in/dateposted-public/
I'm beginning to think that for my typical Internet image postings, I probably don't need anything better than this old D1X.
Akira, thank you for sharing your efforts to make the two images look similar.   Your post processed Z6 image does look much closer to the original 1DX image.  But even after your adjustments, the yellows/greens/reds of the D1x CCD image still look (to my eyes) different than those colors in the processed Z6 image.  Now, which version an individual prefers is up to the individual.  For me, I the yellows/greens/reds of the 1DX still look a bit "richer" to my eyes.
Bruce, one thing to consider is that my computer monitor is just a generic one and not dedicated or calibrated for the image processing.
That said, it should be easy to make the color of Z6 image "richer" even processed from JPEG which is a lossily (sic!) compressed 8 bit data, as opposed to an original 14 bit RAW file.  In this case, I was trying to make it closer to the one shot with D1X.
By the way, I'm curious about the  potential to render the gradation of D1X sensor.  For example, I wonder how it can tackle the rendition of the dawn gradient between orange area around the rising sun and the blue area of the sky?
I think the comparison is similar to that of analog signal on LP records and digital ones on CD.  The dynamic range of the latter is clearly much wider than that of the former.
BruceSD
    • The F/2 Guru
Another photo from my $100 USD, 5-megapixel, Nikon D1x and 105/2 DC Nikkor lens today.
https://www.flickr.com/photos/f2guru/53578163989/in/dateposted-public/
I especially like how these ancient CCD sensors render the color red...
Luc
    • Flickr
This thread reminds me of the comments on the D70s images I posted in this thread https://nikongear.net/revival/index.php?topic=9143.msg151762#msg151762
Luc
    • Flickr
Yes, very nice rendering.
  So do I with one caveat, it is not easy to keep it control. The red channel had a tendency to overblown. I remember having trouble with the shoot of a redhead friend in a red gown and another time with some intense red flowers. still, the results were very pleasing
I am waiting for my batteries to load, but I used the AC Adapter EH-4 to get a shot of Dobby ;)
D1x  AF  50/1.8
BruceSD
    • The F/2 Guru
D1x  AF  50/1.8
I like this photo.  Nice colors and composition.  A noble looking cat.
I would have expected to see a bit more noise in the curtains at the upper right.   Am I correct in assuming that you used base ISO and noise reduction in post?  Because the cat's face remains quite sharp, I expect that if noise reduction was used that you probably painted it in with a brush locally to avoid reducing the subject's sharpness.
Thanks Bruce.
Yes I have used the base ISO here. I did brighten the original  (+0.7) in ACR, did some 'smart' sharpening after resizing but left the noise 'as it is'. So post-processing was limited on this image.
Li-On batteries are now available for the Nikon D1x instead of the unreliable NiMH.
https://electropapa.com/en/battery-replacement-for-nikon-en-4-1800mah-72v-li-ion-500268400  Pretty cheap in Europe via Amazon
BruceSD
    • The F/2 Guru
John, I have exclusively been using NiMH batteries in my two Nikon D1X cameras for some time now, and have had no problems with them.   I have no expertise in battery technology, and would love to learn why Li-On batteries are better than NiMH.  Do Li-On batteries last longer?
Yes
"High-quality Li-ion cells for optimal device performance: " *)
Lithium-ion batteries have a high energy density and are among the most powerful batteries.
Compared to NiMH batteries, they have a low self-discharge rate and are not subject to memory effect.
They do not require regular discharging so are low-maintenance.
 When correctly stored, these rechargeable batteries have a long service life, are durable and have a high number of possible charging cycles.
 Li-ion batteries are used in various portable devices with high energy requirements e.g. smartphones, notebook computers, cameras and power tools. These batteries can also be used in radio-controlled models and telecommunication applications.
*) Quote from the link I posted earlier.
Streetgarden
D1x with the Nikkor AF-D 50/1.4
