Author Topic: So, the ZF ...  (Read 177505 times)
Re: So, the ZF ...
« Reply #420 on: April 19, 2025, 12:51:18 »
So would the #116 feature request, if implemented, result in the instance of a chipped non-AiS lens,  in accurate exposures at the actual aperture set on the lens and notified to the Z body by the photographer via the appropriate menu screen?  Is this what is envisaged?
Then NG members should rally to cast their votes.
Implementing the #116 feature would make Zf operate like the Df if the user so wishes.
Should be very easy to implement in firmware as the functionality is there already with Voigtländer Z and Viltrox Z lenses (for the latter if they have aperture ring). Setting the aperture directly on these lenses will override any camera dialling, unless they have an "A" setting emulating the aperture lock of F-mount Nikkors. This option is seen only on the Viltrox lenses as far as I can recall. The Voigtländer + Viltrox approach makes the choice indirect not explicit like we saw on the Df.
Re: So, the ZF ...
« Reply #421 on: April 19, 2025, 13:27:21 »
Chipped non-AiS lenses can never be stopped down correctly, due to the non-linear aperture mechanism. An example: Using the CPU communication and setting the lens to f/11 (either by moving the aperture ring, or dialling in the number from the camera's side), for example, will make the camera calculate the correct exposure for that f-number. However, when the actual exposure happens, the lens is ordered to stop down to the position corresponding to f/11 on a linear scale. For a non-AiS lens, that means there will be over- or undershoot of the final aperture with the end points of the aperture scale only being correct.
In most cases, the deviation is +-1 stop or less, so the latitude of the digital system can assist in the later post processing. A few lenses will show greater variability and one should from experience be able to use manual exposure and a correction to handle these situations.
To reiterate: the exposure is set correctly, but the non-AiS lenses don't work as expected under a linear aperture model. Thus under- or overexposure will result.
For an AiS lens, setting the aperture on the lens in fact will produce a more even and consistent exposure. Stop-film makers tell me this advice actually helps a lot when they work under fixed light settings in a studio.
The underlying reason why I'm pushing the suggested #116 option is that the camera will handle much better if not all controlling actions are on the right hand. One can use the left hand to support the lens and concomitantly set the aperture, which leads to a much better grip and stability. Nikon Df handled easily in that manner and I do wish the same with the Zf.
Re: So, the ZF ...
« Reply #422 on: April 19, 2025, 16:04:16 »
Thanks Birna - as I suspected, but I had to ask.   :)
Re: So, the ZF ...
« Reply #423 on: April 19, 2025, 19:32:35 »
Before we are carried away with the misconception that using non-AIs lenses is hopeless and inaccurate, do keep in mind that most scenes in practice has a range of exposure possibilities. Their light reflectivity is not perfectly constant and fixed all over the viewed scene.
Without  a controlling CPU, an automatic aperture lens like the earlier Nikkors would operate wide open until the moment of shutter release, then in a fraction of a second stop down until the stop-down lever in the camera hits a hard stop (in the lens). This means even such lenses would provide the exact aperture you had set the lens to. The problem arises only when the movement of the stop-down lever *in the camera* is controlled by electronics communicating with the lens itself. For an Ais lens, the actual and pre-computed movement of the lever coincides; with a non-AiS lens they usually do not.
The above explains why adding a CPU to the lens makes it possible for the camera to control the lens even though the option never was intended, or envisaged, when the lens was built. I have many many older CPU-enabled Nikkors and they operate perfectly on all DSLRs since the D1 (1999/2000) and Z/FTZ since the Z7 (late 2018, oh time flies).
Re: So, the ZF ...
« Reply #424 on: April 20, 2025, 16:06:35 »
Thank you and noted.  Indeed I still use my chipped non-AiS lenses on Z bodies in the manner you describe.
Before we are carried away with the misconception that using non-AIs lenses is hopeless and inaccurate,................................
Re: So, the ZF ...
« Reply #425 on: May 04, 2025, 10:32:50 »
A minor bug:  while firmware 2.0 allows you to dial in f-number with apparently unlimited values, you cannot have an f-number < 0.95 (is this due to the new 'Noct' 58mm f/0.95 ??).  I may set say 0.7, but it will be 0.95. So when I get my new Oude Delft 50mm f/0.75 soon and make a Zf-compatible  mount for it,  I cannot set the correct aperture. Sad.
Snoogly
  • Flipping the bird
Re: So, the ZF ...
« Reply #426 on: June 17, 2025, 10:12:17 »
I am now seriously considering selling my ZF (and maybe Z6ii) and getting a Z5II. If nothing else, the User settings on the Z5 make it massively more practical than the ZF.
I love the ZF, but ..
Re: So, the ZF ...
« Reply #427 on: June 26, 2025, 09:32:25 »
In what kind of shooting scenarios do you need the user settings in?
For me there has not been any situation where I would have thought the Zf user interface gets in the way.
The only two complaints I personally have about the Zf are (1) the fully articulating screen is annoying; I would prefer a two- or even one-axis tilting screen where the screen stays on the optical axis at all times and (2) there is no support for MC-30A or WR-R10(a/b) so there is no electronic (non-bluetooth) remote release and there is also no way to radio trigger the SB-5000. Otherwise it's such a nice camera.
Re: So, the ZF ...
« Reply #428 on: June 26, 2025, 10:23:30 »
The lack of a remote release port is the most annoying flaw of an otherwise near-perfect camera.
aerobat
Re: So, the ZF ...
« Reply #429 on: October 28, 2025, 13:29:21 »
Daniel Diggelmann
Re: So, the ZF ...
« Reply #430 on: October 28, 2025, 14:28:17 »
Dear colleagues - FW 3.0 is out:
https://downloadcenter.nikonimglib.com/en/download/fw/577.html
I've had this annoying experience that when folding out the back screen to be used on the left side, my camera strap would often cause the EVF eye sensor to think that I'm using the EVF. This FW update will apparently let me configure the camera so that the eye sensor is not able to shut down the back LCD when folded out. I'll test this soon. I guess I'm not the only one who found this to be an issue in use.
Update: the new option does work as advertised. I might dislike the folding-out screen a bit less now. ;-) It is nice to see Nikon pay attention to usability details in the firmware updates.
Nasos Kosmas
  • Athens, Greece
Re: So, the ZF ...
« Reply #431 on: October 30, 2025, 16:43:34 »
What about the film grain option, did anyone tested?
Thanks
Re: So, the ZF ...
« Reply #432 on: October 30, 2025, 16:52:51 »
You can freely destroy an image by massive amounts of grain :) Or pull back the effect to more subtle levels.
In short, this feature works. Sort of.
Re: So, the ZF ...
« Reply #433 on: October 30, 2025, 17:48:25 »
It looks close to real grain...but still not perfect :o :o :o
Re: So, the ZF ...
« Reply #434 on: October 30, 2025, 19:50:01 »
Those grain options should be part of post-processing (if you want to destroy the image) ;)
