Author Topic: So, the ZF ...  (Read 179952 times)
Re: So, the ZF ...
« Reply #390 on: March 31, 2025, 12:04:43 »
Thanks to you both!  This seems like a very welcoming community  :)
I did pick up a 105 f/2.5, the 85 f/2, and a 28mm f/2.8. I'm currently trying out the 50mm 1.8 pancake, but think I like the 1.4 a bit more.
Now, I need to stop!  I had gone down a similar Nikon rabbit hole when building a kit of cheap lens for my kids to do stop-animation last Christmas.  I hadn't known much about Nikon lenses, but enjoyed that process so much that the ZF began calling....
250329_NicoSkeptical by Tom Quinn, on Flickr
I would suggest to look into one of these beautiful Voigtländer Optics, whgich brought back great joy to my photography using the Zf:
https://www.voigtlaender.de/z-mount/?lang=en
Stunning quality and 100% compatible like native Z-Lenses.
Love
Frank
Re: So, the ZF ...
« Reply #391 on: March 31, 2025, 13:15:09 »
  Beautiful use of the lighting in both images. Thanks for sharing it
tq_photofilm
  • You ARE NikonGear'23
Re: So, the ZF ...
« Reply #392 on: March 31, 2025, 13:49:35 »
Thanks!
And Frank, I'd love the Voigtländer, but am afraid the budget is limited at the moment.   I hope to in the future!
I tried out the TT Artisan 6-bit adapter to get focus confirmation on the non-CPU lenses.  It works fairly well, but seems to confirm early.   It also is limited in that you can only add a stop up to 5.6, so the aperture priority shooting does not work reliably (and actually works better with no CPU data).   I'm going with the Shoten instead.
Re: So, the ZF ...
« Reply #393 on: April 08, 2025, 12:31:19 »
Maybe superfluous at this point.. the firmware update, fw2.00 for the Zf camera.
https://www.youtube.com/watch?v=h1jsDQNuwR8
Re: So, the ZF ...
« Reply #394 on: April 08, 2025, 14:17:03 »
Very interesting improvement to the use of non-CPU lenses :)
Do note, however, that the new ability of recording the intended aperture used with the non-CPU lens *does not* imply the aperture will be set accordingly... you do have to put the lens manually to that aperture setting first by using the aperture ring. This is of course due to the lack of an aperture follower inside the FTZ-class adapters.
Still, a very worthwhile, and welcomed, improvement to the Zf.
Perhaps we can get a GPS option in the future? Or FTZ.3 with an aperture follower inside?
Re: So, the ZF ...
« Reply #395 on: April 08, 2025, 19:59:30 »
Just updated firmware on my Z9 to the latest version 5.10. Interestingly, the Zf with firmware 2.00 has currently better support for manual lenses and their operation than does the flagship Z9.
Ian Watson
Re: So, the ZF ...
« Reply #396 on: April 09, 2025, 16:32:37 »
I like the new custom setting d18. It enables the viewfinder zoom to be cancelled with a half-press of the shutter release.
Re: So, the ZF ...
« Reply #397 on: April 09, 2025, 17:39:59 »
I use the front function button for toggling zoomed views. Since I have a soft-release thingy affixed to the shutter release, I can't use the d18 option. The latter would require more finger movement as well, at least for the manner in which I operate the Zf.
Good that every user can optimise the features as they see fit :)
Jürgen Pfeiffer
Re: So, the ZF ...
« Reply #398 on: April 10, 2025, 10:25:14 »
Birna, give D18 a chance. On the Zf I also put the zoom function on the function button and the shutter release also has an AR-11 button on it. With D18 on, I have the impression that the zoom out and then release sequence is faster, especially with (slow) moving subjects as shown here.
I also find the new option of entering lens names very practical; the photo shown now has the correct name in the EXIF: “Focomat 6cm F4.5”.
Jürgen Pfeiffer
Re: So, the ZF ...
« Reply #399 on: April 10, 2025, 12:04:51 »
... the FocoCat ...
Re: So, the ZF ...
« Reply #400 on: April 14, 2025, 22:30:10 »
Firmware 2 is nice. Now the Zf works like the Df when the latter is mounted with a pre-AI lens. For slow (and not too forgetful) photographers, that is pretty good.
Indeed, the d18 setting (un-zoom by half pressing) is also a bonus.
Recording the non-CPU lens names could have been better : why are there only 20 available slots? I have a dozen "fifties" !!!
Re: So, the ZF ...
« Reply #401 on: April 14, 2025, 22:50:49 »
Any thoughts on the image quality of the Zf v. the D850?
What about the use of legacy manual focus lenses on the Zf, specifically focus issues? My vision has dropped from years of 20/15 with glasses to 20/20. I can no long get much use of these lenses on the D850.
Thanks for any insights you can provide.
Best,
Re: So, the ZF ...
« Reply #402 on: April 14, 2025, 23:47:15 »
Using manual lenses on the Zf is easy and better than on most of the DSLRs (except for the Df?)
The main issues is handing due to the added FTZ/FTZ.2 and the concurrent movement of controls further away from the camera. Balance becomes off. For lenses up to 105(-135), not a deal breaker, but can get worse or annoying for many longer lenses, at least for hand-held shooting.
If you are convinced that 45+ MPix is required for your photography, perhaps Z7, Z8, or Z9, would be preferred to the Zf.
Re: So, the ZF ...
« Reply #403 on: April 15, 2025, 01:23:21 »
Thank you Birna.
Ian Watson
Re: So, the ZF ...
« Reply #404 on: April 15, 2025, 15:40:32 »
I would add that the foot on the original FTZ is annoying when using manual lenses. If you have no need for electronic contacts in your adapter then a decent dumb adapter will be usefully cheaper and more svelte.
