Author Topic: [Theme] Trees  (Read 135489 times)
Re: [Theme] Trees
« Reply #390 on: April 07, 2025, 08:34:08 »
Oaks
D5 24-70vr
KarlMera
Re: [Theme] Trees
« Reply #391 on: April 07, 2025, 11:38:10 »
An experience
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #392 on: April 08, 2025, 19:57:02 »
Victims of the prevailing wind?
Thanks Hugh, I was thinking what the cause could be myself. The trees are located at the edge of a forest with tall trees (to the left) and a meadow with moist soil (to the right). Maybe stretching towards light and then the extra weight causing the trees to tilt and sink into the the soil. On the other hand, it could also be characteristics of the specific tree species - looks like a multi trunked Beech (smooth trunks).
Re: [Theme] Trees
« Reply #393 on: April 08, 2025, 20:16:31 »
Thanks Hugh!
Nice scene, although I am not sure about the orange circle.  A lab artifact?
I develop the films myself. But, Catlabs respools some other brand film, probably Kodak (i haven't checked) and somehow each roll has this spot/dot at the end of the film.
It seems i need to wind the film just shy of the designated numbers to avoid this (i only found this pattern with this roll). Usually i do crop it out, but since it took on the colour of the sun that happens to be positioned where the dot is, i thought to do something different this time. YMMV of course
What lenses are you using Hans?  Are they from a 4x5 large format camera for example?
The write ups about the Shenhao 617 seem quite favourable.
The Shenhao is certainly quite nice, i have the PTB617, which is the folding model. I do use large format lenses and have taken care to make sure the image circle is large enough to cover 6x17 cm and space left for movements which ups the requirement to 5x7 inch lenses.
Re: [Theme] Trees
« Reply #394 on: April 08, 2025, 21:17:37 »
busy tree
KarlMera
Re: [Theme] Trees
« Reply #395 on: April 09, 2025, 12:22:38 »
Realistic
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: [Theme] Trees
« Reply #396 on: April 09, 2025, 14:35:10 »
Campillo de Adentro. Canara START, lente: HELIOS 44
KarlMera
Re: [Theme] Trees
« Reply #397 on: April 11, 2025, 12:01:15 »
In the background
senecaman
Re: [Theme] Trees
« Reply #398 on: April 14, 2025, 16:03:59 »
Ageing gracefully
Andrew
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #399 on: April 14, 2025, 20:03:50 »
Re: [Theme] Trees
« Reply #400 on: April 14, 2025, 20:07:32 »
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #401 on: April 15, 2025, 14:58:58 »
Very nice comparision, Lars !
Many thanks, John! Apart from the tree and the different season, I found the "white spots" on both images to be a fun similarity.
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #402 on: April 15, 2025, 15:22:46 »
Ageing gracefully
Very nice, Andrew - both the tree and the scenery!
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #403 on: April 15, 2025, 15:32:03 »
Watching Andrews shot, I remembered this tree from the local lake. Also tilting towards the water - an old tree with twisted and broken branches. It was its last summer (2024) standing - a storm later brought it down. Nikon Z 50/f1.8 @f1.8 - intentionally kept the light fall-off.
KarlMera
Re: [Theme] Trees
« Reply #404 on: April 16, 2025, 11:11:29 »
Atmosphere of departure
