Author Topic: Projection lenses  (Read 133770 times)
Toby
    • Toby Marshall
Re: Projection lenses
« Reply #270 on: October 11, 2018, 22:18:19 »
Hi Klaus,
How can I modify my 50 f1 to focus a bit further away? I assume one has to move the rear elements closer to the front elements...
« Reply #271 on: October 12, 2018, 07:00:24 »
Hi Klaus,
A skilled mechanic has to take the rear lens part out, shorten and modify the barrel, then set the rear lens part in again, either glued or screwed.
I have a guy here in Germany who does that... (only works if lens is free of dents especially on rear part, only one of my four worked)
Grahame Hamblin
« Reply #272 on: October 13, 2018, 02:23:24 »
old lens 85mm caenaho  on rim
tiny flower hand held liked the colour
Grahame
« Reply #273 on: October 13, 2018, 10:07:21 »
Grahame
excellent - can't believe this was handheld!!
Grahame Hamblin
« Reply #274 on: October 14, 2018, 06:53:06 »
thanks Klaus. I use an old shooting technique from my early
rabbit shooting years using what is called a snipers rig. a simple strap attached to my camera and around upper arm held taught. it braces whole body like a tripod. Simple but it works and cheap $5 at most
Grahame
« Reply #275 on: October 15, 2018, 09:10:09 »
Grahame
I know that, learned it myself. Congrats!
« Reply #276 on: November 16, 2018, 20:47:12 »
Got two Pathe Freres Paris projection lenses (65mm + 85mm) through a friend,
guess they are from the 1920s..
Some shots with the 65mm mounted on my GH4, taken at last sunlight...
« Reply #277 on: November 16, 2018, 21:23:07 »
Some shots with the 65mm mounted on my GH4 at evening light
Beautiful renditions.  Probably one of my favorite lenses among your collection.  Thank you for sharing!
« Reply #278 on: November 17, 2018, 14:25:43 »
Yes indeed, this and my 80mm Hermagis do very well still today, both being nearly 100 years old!!
koondr
« Reply #279 on: November 30, 2018, 13:16:11 »
RODENSTOCK HELIGON 100/1.6
koondr
« Reply #280 on: November 30, 2018, 13:19:26 »
koondr
« Reply #281 on: November 30, 2018, 13:22:45 »
Meyer-Optik Gorlitz Kinon 2.1/200
koondr
« Reply #282 on: November 30, 2018, 13:29:29 »
 КО-120 120 mm f/ 2.1
koondr
« Reply #283 on: November 30, 2018, 13:55:32 »
35КП 140мм f1,8
« Reply #284 on: November 30, 2018, 13:59:48 »
It appears you have used these lenses to their fullest advantage, Vladimir. Really nice portraits in an environmental setting.
