Author Topic: Projection lenses  (Read 185734 times)
Re: Projection lenses
« Reply #285 on: November 30, 2018, 14:05:11 »
Beautiful yes.  Impressive results with the Heligon 100/1.6
koondr
« Reply #286 on: November 30, 2018, 14:14:32 »
thank :)
koondr
« Reply #287 on: November 30, 2018, 14:17:24 »
It appears you have used these lenses to their fullest advantage, Vladimir. Really nice portraits in an environmental setting.
thank you very much
koondr
« Reply #288 on: November 30, 2018, 14:20:48 »
 Rodenstock Heligon 100mm f/1.6
« Reply #289 on: December 01, 2018, 12:09:44 »
Looks very good to me Vladimir!!
koondr
« Reply #290 on: December 01, 2018, 12:14:18 »
thank you for a review
« Reply #291 on: December 01, 2018, 12:52:31 »
At this point I'm sure a lot of our members would like to learn more of the actual setup (camera/focusing unit/lens) used. And more photos, too :D
« Reply #292 on: December 01, 2018, 13:11:19 »
Indeed a crash course for dummies to set up a dslr for exotic lenses, mounts, helicoids, adapters, etc..
thanks
« Reply #293 on: December 01, 2018, 13:43:25 »
thanks
+1 ;)
« Reply #294 on: December 01, 2018, 14:39:30 »
+2¡
koondr
« Reply #295 on: December 01, 2018, 15:07:49 »
 Rodenstock Heligon 100 мм f / 1,6
« Reply #296 on: December 01, 2018, 15:25:25 »
Thank you very much. I have a similar set up for my Nikon Z's, but the heavy lens in front makes the helicoid a  bit sticking and rough in operation. Thus I will research alternatives for a more permanent solution.
« Reply #297 on: December 01, 2018, 15:44:09 »
Nice setup !   So you have a separate helicoid with an aperture-ring, to stop down the lens?
« Reply #298 on: December 02, 2018, 01:44:25 »
Guess I had posted that before: http://photographyoftheinvisibleworld.blogspot.com/2015/09/how-to-modularily-mount-projection-or.html
« Reply #299 on: December 02, 2018, 02:24:13 »
Such lenses and also projection lenses are usually used open, as they have no aperture.
Some people either perform some (delicate) surgery and add one (I have a few done by a very skilled mechanic),
or use an added aperture after the lens (enough back focal permitting), but that often leads to vignetting). A front
aperture is possible too, but for large lenses bit difficult to make and use.... But why bother, the idea is to USE
such a lens for its BG separation, requiring the full opening to achieve that.
