Author Topic: April 2021  (Read 53465 times)
Kim Pilegaard
  • "Nikea"
Re: April 2021
« Reply #150 on: April 16, 2021, 11:06:42 »
I have an even older Novoflex Fernobjektiv 1:5.6 f=40cm. It does not have the pistol grip but can be used with a Novoflex bellows. Here it is attached to the camera with a Novoflex NEXA and an Sony E to Nikon Z adapter.
For the latest incarnation of the Novoflex follow-focus lens, there exists a replacement for the pistol grip with a focusing mechanism; the Novoflex TUBUS-D. It is very solid but rare. I tried to get one a few years ago in an auction, but didn't win.
Kim
Re: April 2021
« Reply #151 on: April 16, 2021, 11:19:34 »
Kim, a nicely looking Novoflex!! I too have a "Fernojektiv f=40cm", but obviously the exterior is differerently finished. Both likely are nearly 60 years old by now.  In my really young days I sometimes borrowed a friend's Novoflex with the Pistol Grip for shooting wildlife, a feat which I never mastered to satisfaction. Thus the idea of the Novoflex hibernated until the last couple of years, when Ulf Wilhelmsson, a Swedish member of UVP, demonstrated the vintage Novoflex passed a lot of UV. So I bought into the 'Schellschuss' system again, but quickly found the Pistol Grip idea would not work for UV in the field. Hence the dedicated setup shown in a previous post.
Kim Pilegaard
  • "Nikea"
Re: April 2021
« Reply #152 on: April 16, 2021, 12:29:12 »
Mine is from the 50's. The advantage of this one is that it actually has a tripod socket just behind the aperture element. The lens head can also be rotated. The specific lens is most likely made for a Leica. It ends in a 39mm thread, which fits the Novoflex belllows.
Kim
Re: April 2021
« Reply #153 on: April 16, 2021, 13:50:52 »
Both look gorgeous!
Do these "Fernobjektive" consist of a single optical design of two glued convex- and concave elements like Leica Telyt 560mm and 480 lenses?
Kim Pilegaard
  • "Nikea"
Re: April 2021
« Reply #154 on: April 16, 2021, 14:53:11 »
Both look gorgeous!
Yes, as far as I know, the only one with 3 lenses is the newer T-Noflexar f/5.6 400mm.
Kim
Luc
    • Flickr
Re: April 2021
« Reply #155 on: April 16, 2021, 19:17:19 »
Eemhuis (library, arts centre), Amersfoort/The Netherlands
Nikon Z6 + Voigtländer 75mm f1.5 Norton VM
Re: April 2021
« Reply #156 on: April 16, 2021, 19:24:09 »
Thank you, Kim, for confirmation and details.
Re: April 2021
« Reply #157 on: April 17, 2021, 05:52:50 »
Re: April 2021
« Reply #158 on: April 17, 2021, 07:02:49 »
Clean image of the Eemhuis, Luc.
On an iron wall close to City Hall there are two mail-boxes where concerned citizens can complain...  In the background the revived City Hall
Z6  58/1.4G
Re: April 2021
« Reply #159 on: April 17, 2021, 08:06:03 »
April 16
blush roses
D3s, 24mm f/1.4
Great shot, Fons.
Re: April 2021
« Reply #160 on: April 17, 2021, 08:20:44 »
Thanks John, the 24mm f/1.4 seems to be an overlooked lens nowadays, not up to modern ideas of sharpness etc.
Re: April 2021
« Reply #161 on: April 17, 2021, 08:31:05 »
Yes, I compared this lens with the new 28/1.4 E and the latter wins on all accounts, also  very good up close.
Re: April 2021
« Reply #162 on: April 17, 2021, 09:19:15 »
Have both the 28mm wins where acute sharpness is wanted the oof of the 24 is preferred.
Kim Pilegaard
  • "Nikea"
More fun with long lenses ...
« Reply #163 on: April 17, 2021, 09:58:55 »
The setup below is inspired by this thread: https://www.dpreview.com/forums/post/53810416
I found the idea of using a Canon 500D close-up lens as a telephoto lens quite interesting. The Canon is a 2-lens design (doublet achromat) like the Noflexar long lenses (except the T-Noflexar).
I made a setup with a PB-6 bellows, the extension bellows PB-6E, a PN-11, the extension rings PK set, some step-up rings, and the Canon 500D 72mm.
The result is a f/9.6 500mm. The limit for aperture is the 52mm diameter of the tubes.
Below a picture of the setup and an example picture with a crop. It is seen from the full picture that there is some vignetting.
This is the crop - the other pictures follow.
Kim
Kim Pilegaard
  • "Nikea"
Re: April 2021
« Reply #164 on: April 17, 2021, 10:01:05 »
The setup:
Kim
