Author Topic: 1 Nikkor 18.5mm f/1.8  (Read 13131 times)
Re: 1 Nikkor 18.5mm f/1.8
« Reply #45 on: March 24, 2021, 10:57:06 »
https://nikongear.net/revival/index.php?topic=9901.msg169670#msg169670
I linked in the other thread on the same Nikon 1 lenses  ;D
As always you can rely on Rolands pages for such information
http://www.photosynthesis.co.nz/nikon/specs.html#1NIKKOR
PM is indication of Plastic Mount
I see......and 18.5 has the indication "PM".....and that is 99.99% correct :-)   .....it would also be my best guess.....but.....maybe it is still metal......below the coat.....
« Reply #46 on: March 24, 2021, 11:44:15 »
Different materials are chosen for wear resistance and mainly to prevent galling
mxbianco
« Reply #47 on: March 24, 2021, 19:01:55 »
According to Roland's Bible, the featherweight 18.5mm (only 70 grams, compared to 77 g of the 10mm/2.8 and 235 g of the 32/1.2 ), can safely get away even with a plastic mount. I would not worry too much!
Ciao from Massimo
« Reply #48 on: March 25, 2021, 20:26:56 »
It's very comprehensive and 99.9999% accurate,,, :o :o :o
That implies only one error in one million entries. I don't even have that many data points, and I am sure there is more that one error or inaccuracy :) :o
« Reply #49 on: March 28, 2021, 13:02:17 »
Gerhard2006
« Reply #50 on: March 30, 2021, 07:00:19 »
this lens is my favorite for the V1 , the f1.8aperture allows me to keep the ISO below 800 , a bit bulkier than the 10mm f2.8 but way sharper
the ergonomics of my v1 can be annoying, but I've learned to live with it
I agree with you Armando that's why when I bought my V1 I bought the Nikon grip and later got even a cheaper one for it on eBay. The original grip I adapted to my J5 and cut off the little snibs(for lack of a better term) so the screen would still tilt.The grip made the camera so much more enjoyable to use. Regards Gerry
GraXXoR
« Reply #51 on: April 22, 2021, 21:15:33 »
Big fan of the 18.5 1.8.. Just got into the N1 ecosystem at the end of January after picking up a V2 with 10-30 and 30-110 to play with... Now, somehow only just over 2 months later,  I have a V2, V3, 6.7-13, 10mm, 18.5mm, 10-30 pd and non-pd, 30-110, 10-100, SB-N7, GN-N100...  "Just" missing the 32 and the 70-300.... Like, those two lenses will double the cost of my entire setup.
Anyway, big fan of the 18.5mm. what a nice closeup performance.
« Reply #52 on: April 23, 2021, 01:35:05 »
great shots! :o :o :o
im thinking of selling mine since i do not use it much  ::)
GraXXoR
« Reply #53 on: April 23, 2021, 18:10:28 »
Richard,
I think that with the lack of durability of the N1 series lenses, it's always good to have a backup... I've got two of each of the cheapie lenses... 10, 18.5, 10-30 and 30-110...  These things really are less consumer grade, more consumable grade.
