Author Topic: 1 Nikkor 18.5mm f/1.8  (Read 13241 times)
Re: 1 Nikkor 18.5mm f/1.8
« Reply #30 on: March 23, 2021, 11:55:22 »
The mount is the same material throughout. I made a quite deep scratch :) definitively not just metal coat on something else inside.
The material might be aluminium.
« Reply #31 on: March 23, 2021, 12:03:30 »
Ok.....but mount on PD 10-30 zoom looks 100% identical to the 18.5 mount.
Could we conclude that no mounts are made of metalized plastic?
« Reply #32 on: March 23, 2021, 12:28:53 »
from ebay :o :o :o
its injection molded but it doesnt appear to be made of plastic, probably some kind of nickel alloy. ::) the same material used on some metal internals of ai-s and later lenses
« Reply #33 on: March 23, 2021, 12:42:18 »
Ok.....so the reason why the 10/2.8 feels more heavy might be that this mount is chromed brass....so a "real" Nikkor mount on this one?
And maybe also on 32/1.2 and 70-300?
« Reply #34 on: March 23, 2021, 12:48:34 »
i think this is for the 10-30mm if i am not mistaken when i made the search query :o :o :o
« Reply #35 on: March 23, 2021, 12:59:47 »
Is there a possibility that Nikon has changed the material from start to end of production, as mine 18mm really feels like plastic?
Bought late in the Nikon 1 history ;)
« Reply #36 on: March 23, 2021, 13:04:03 »
possible... ::)
this alloy actually feels like plastic. if you read my articles you will see a greyish metal inside of some ai-s and later lenses. this is the same brittle alloy if i am not mistaken, definitely zinc-nickel or most likely :o :o :o
« Reply #37 on: March 23, 2021, 16:08:12 »
This is a 10-30mm Nikon 1 lens mount - Looks like injection molded metal zinc-aluminum alloy then the mount face is finished on a CNC mill for accurate dimensions.
Strong, light and well suited mating surface for the cameras mount surface.
By far strong enough for the small light Nikon lenses.
« Reply #38 on: March 23, 2021, 16:34:34 »
I was quite disappointed when I found out that my Nikkor 1 lenses has mounts of painted plastic......but it seems not......so a bit more happy with my lenses......
What material is the mount of the 10/2.8?    .....chromed brass?
mxbianco
« Reply #39 on: March 23, 2021, 17:20:00 »
I use a 40.5 to 52mm step-up ring on my 18.5 mm lens in order to be able to use standard 52mm filters (e.g. polarizer and L37c filter).
Then a lot of standard Nikon lens hoods can be used also. A 40.5 to 52mm step-up ring is cheap. I use a standard 52mm Nikon lens cap for the lens.
The dedicated 18.5mm hood has a thread for attaching 40.5mm filters or adapters. The usefulness of this particular hood is that you have good flare protection and the camera looks like a cheap consumer-grade one (very useful for on-street photography). I did the 40.5 to 52mm step-up ring trick with the 10 mm lens, and I could reuse an old foldable Nikon rubber hood. With the unextended hood, a 1V1 + 10mm will have a humble look, unlike one with a full size protruding hood. Either way, nobody will consider you as a paparazzi, or as a potential robbery target...
Ciao from Massimo
« Reply #40 on: March 23, 2021, 18:27:40 »
this lens is my favorite for the V1 , the f1.8aperture allows me to keep the ISO below 800 , a bit bulkier than the 10mm f2.8 but way sharper
the ergonomics of my v1 can be annoying, but I've learned to live with it
with the X-T3 I keep forgetting where things are and the menus are a pain to scroll through
the best is still my D800
With the 18.5 the image quality is better than photos from a mobile
« Reply #41 on: March 24, 2021, 08:49:28 »
As I posted the link already for Rolands pages, please look up any Nikkor you like to know more about  8)
http://www.photosynthesis.co.nz/nikon/
It's very comprehensive and 99.9999% accurate,,, :o :o :o
« Reply #42 on: March 24, 2021, 09:52:51 »
Where do I find information for which material the bayonet is made of?
What is "funny" is that I am able to make a mark into the bayonet shinny part with my nail. But maybe the shinny part is a thin coat?
And why do Nikon coat it if it is made of metal?
The mount on FT1 adapter is very different.....it "smells" of metal from far distance :-)  it feels like several steps up in quality and I would have liked this bayonet mount on Nikkor 1 lenses......
« Reply #43 on: March 24, 2021, 10:42:40 »
https://nikongear.net/revival/index.php?topic=9901.msg169670#msg169670
I linked in the other thread on the same Nikon 1 lenses  ;D
As always you can rely on Rolands pages for such information
http://www.photosynthesis.co.nz/nikon/specs.html#1NIKKOR
PM is indication of Plastic Mount
« Reply #44 on: March 24, 2021, 10:53:03 »
plating helps create a protective coating :o :o :o and also make it look "decent" ::)
