Author Topic: Well, I cocked-up and bought a 50mm Meopta projector lens  (Read 2643 times)
Snoogly
  • Flipping the bird
I purchased an optically lovely Meopta Meostigmat 1/50 lens, but have discovered it doesn’t work on my D750. I have the correct combination of clamps, rings, and focusing helicoid, but it’s all just a blur for anything not just a few cm in front of the lens.
I think I cocked-up, right? To make it work needs major surgery?
The eBay seller doesn’t accept returns, so I think I am stuck with it - unless someone wants to take it off my hands!
Re: Well, I cocked-up and bought a 50mm Meopta projector lens
« Reply #1 on: March 11, 2021, 09:00:49 »
Are you sure you have determined the right register distance ?
The lens is probably still too close from your camera sensor. If you have a bellow, you can try to pull the lens until you get a sharp image.
« Reply #2 on: March 11, 2021, 09:47:47 »
This one is a very special lens which needs quite some mechanical modification to make it work. The rear optical group needs to be taken out, the rear barrel shortened and made smaller, optics group reinserted and glued in or fixed with three set screws (as the barrel has been changed). Needs a skilled mechanic (I have one). THEN it will work even to infinty (but ONLY on mirrorless cameras, not DSLRs with their massive 46.5mm register length). Anyway not a good lens to start with honestly....
Get a 1.4/70mm - much easier to use and a top lens for portraits especially! Or even a longer focal legth, the 1.7/100mm or 109mm, superb lenses but 62.5mm diameter. The latter longer ones can be adapted to those old DSLRs.
You can find results of all them here: https://www.flickr.com/photos/kds315/albums
Results with Meopta 1.0/50mm are here: https://www.flickr.com/photos/kds315/albums/72157689252505212
Snoogly
  • Flipping the bird
« Reply #3 on: March 11, 2021, 10:01:34 »
So at least I  happy I did actually cock-up 100%!
If anyone wants this (ideally in Japan, but not limited to), let me know!
« Reply #4 on: March 11, 2021, 21:51:45 »
Good results, esp. considering the aperture : the pics are pleasant overall, while some decent sharpness level is reached in the middle.
Snoogly
  • Flipping the bird
« Reply #5 on: March 12, 2021, 00:59:37 »
Would you like my lens? ;-)
« Reply #6 on: March 12, 2021, 14:27:53 »
No, but only because I have not switched to mirrorless (yet). Besides, I broke the bank buying another hard-to-find lens earlier this year (VoigtLänder 180/4). Do not tempt me!
« Reply #7 on: March 13, 2021, 21:52:02 »
Since when would EUR100 for a converted lens "break the bank"? ;-)
Snoogly
  • Flipping the bird
« Reply #8 on: March 14, 2021, 00:25:58 »
It’s a shame it’s just sitting here, looking sad and naked :-(
« Reply #9 on: March 16, 2021, 09:00:05 »
Get a mirrorless camera and you have a chance to use it...
Snoogly
  • Flipping the bird
« Reply #10 on: March 16, 2021, 10:48:35 »
Actually, by trading in a bunch of stuff at mapcamera, a Z5 will be heading my way as soon as they have processed my donations.
What will be involved to make it mirror friendly, without major surgery?
« Reply #11 on: March 16, 2021, 13:24:23 »
This is a good start point:
https://nikongear.net/revival/index.php?topic=9130.msg151598#msg151598
« Reply #12 on: March 16, 2021, 17:21:32 »
Unfortunately NOT, lens surgery needs to be done even at 18mm back focal length...
« Reply #13 on: March 16, 2021, 17:29:51 »
Here is a FB group dealing especially with this:
https://www.facebook.com/groups/2161767920526039/
« Reply #14 on: March 17, 2021, 10:32:42 »
Yes, major surgery depending on infinity or not, you need to trim the lens down that was clear, but then you add a mount and or adapter like in the thread above.
Often for instance such lenses can be modified for 52mm threads as an intermediate step to adapt to different lens mounts,,,
Here info on spare Z-Mount for lens:
https://nikongear.net/revival/index.php?topic=9879.0
