Author Topic: UV-Nikkor 105mm and similar lenses for reflected UV  (Read 8541 times)
« on: January 31, 2021, 16:07:36 »
Measured a few lenses for reflected UV as well as UV-VIS-NIR photography including the famous UV-Nikkor f4.5 / 105mm all but one with Nikon-F mount:
- CoastalOpt (Jenoptik) f4 / 60mm UV-VIS-NIR Macro Apo (Nikon-F mount) http://www.macrolenses.de/ml_detail_sl.php?ObjektiveNr=344
- UV-Nikkor f4.5 / 105mm (Nikon-F mount) (identical to the RAYFACT f4.5 105mm sold by Nikon TOCHIGI) http://www.macrolenses.de/ml_detail_sl.php?ObjektiveNr=298
- Lavision f2.8 / 85mm UV (Nikon-F mount) https://lastek.com.au/2622-lavision-extended-its-portfolio-to-a-uv-lens-designed-for-optimal-performance-with-intensifiers
- Hamamatsu A4869 f3.5 / 50mm (c-mount) http://www.macrolenses.de/ml_detail_sl.php?ObjektiveNr=382
Details are here:
https://photographyoftheinvisibleworld.blogspot.com/2021/01/lens-transmissions-of-specialized.html
JCDowdy
Re: UV-Nikkor 105mm and similar lenses for reflected UV
« Reply #1 on: February 03, 2021, 22:03:10 »
Nice one Klaus!
John C. Dowdy, Ph.D.
« Reply #2 on: February 03, 2021, 22:28:04 »
The UV-Nikkor seems to be the better lens as it covers a FX sensor (and has no dip). The 50mm has higher transmission but covers less area......?
« Reply #3 on: February 05, 2021, 07:22:20 »
Nice one Klaus!
Thanks John!
The Hamamatsu is a c-mount lens and covers 1" sensors, the Lavision APS-C format. UV-Nikkor and CoastalOpt are full format.
The CoastalOpt is useful from about 310-320nm onwards, good enough for biological work, not for technical (Combustion Analysis etc.)
where UV-B and UV-C recording is needed, which all other lenses are capable of.
« Reply #5 on: February 11, 2021, 22:10:46 »
It is the current Rayfact incarnation of the legendary UV-Nikkor. Except for some cosmetic differences regarding the engraved data, they are identical.
These lenses are purely manual focusing and hve excellent workmanship, to last virtually forever. My UV-Nikkors are 30 years old by now and still function perfectly.
« Reply #6 on: February 11, 2021, 22:44:24 »
It looks almost as nice as my AIS 105/4 micro.
He has to try hard to make me swap.....
« Reply #7 on: February 11, 2021, 23:18:44 »
The exterior of the UV-Nikkor (and Rayfact UV105) is based upon the Micro-Nikkor 105mm f/4 AIS. Even down to the locking screw for the focusing collar. The interior?  different planet. No glass, just quartz and fluorite.
« Reply #8 on: February 11, 2021, 23:38:13 »
They look quite similar. The "front" looks a bit different where the 105/4 has much finer "light diffusers"......if they can be called like that. Smaller steps where 105/4.5 has large steps.
Rayfact makes many lenses "nerds" can get some fun with......it seems. Especially fun with macros. Almost "CA-free" lenses.
« Reply #9 on: February 12, 2021, 10:37:33 »
The UV 105 also has a concave front element. Few lenses at its time of inception had, and still uncommon although the feature is shared with e.g. the current 50mm f/1.8 S-Line Nikkor for the Z system.
By the way, although the UV-Nikkor (and Rayfact UV105) is super sharp, you need to use it for UV to appreciate its quality. For visible range, a UV/IR cut filter has to be used. And the bokeh of the Micro 105/4 is so much nicer. Each to their own [use].
« Reply #10 on: February 12, 2021, 14:06:18 »
Here now a few 85mm lenses... (the dip in transmission of that UAT85 seems to be from using natural fluorite)
« Reply #11 on: June 02, 2025, 08:53:55 »
Well, it has been a while, just noticed that the famous UV-Planar f2/62mm has not been mentioned....(which will not be sold despite letting go a lot of lenses as there are only two known to exist)
This is its rather elaborate 11e/11g optical scheme, which was computed around 1970 by Prof. Glatzel, ZEISS' Designer in Chief at this time:
All that based on a NASA demand for an extraterrestrial lens which covers UVC - NIR (200 - 700nm), but with a speed of f2 using CaF2 (Calcium Fluoride) and synthetic Quartz (fused silica).
And this is how it looks as a finished lens in barrel with adjustable iris built in (the blue light was just a reflection from my PC monitor):
Here on my database: http://macrolenses.de/ml_detail_sl.php?ObjektiveNr=386
This now is a Zinnia haageana shot with that famous lens in visible light, reflected UV and simulated bee vision stopped down to f5.6:
« Reply #12 on: June 12, 2025, 09:42:32 »
Here now the ZEISS UV-Planar 4/60mm, once made for producing finest rulers (micro size) using UV-light...
and using it for photography....(wide open at f4):
and at f5.6:
« Reply #13 on: June 12, 2025, 13:22:35 »
I wonder how the UV-Planar stacks up against the Coastal 60/4 APO?
« Reply #14 on: June 14, 2025, 16:36:39 »
Never made a direct 1:1 comparison unfortunately... ;)
