Author Topic: Gourd - UV stimulated fluorescence into the visible  (Read 1680 times)
« on: November 25, 2020, 00:07:49 »
So I was doing some painting with light and figured I would try some UV stimulated resonance fluorescence into the visible. I used a Nichia UV light with a U-340 filter to stimulate fluorescence in the second image.
Nikon D850, AF-S VR Nikkor 200/2G
25s f/13.0 at 200.0mm iso31
61s f/13.0 at 200.0mm iso31
Re: Gourd - UV stimulated resonance fluorescence into the visible
« Reply #1 on: November 25, 2020, 04:40:25 »
Interesting find, Bob!
Apparently, the one in the middle fluoresces most vividly.  I wonder if you cast a rather narrow UV beam onto it.  It looks dramatic anyway!
« Reply #2 on: November 25, 2020, 05:23:44 »
Lovely false color work, Bob.
« Reply #3 on: November 25, 2020, 09:47:31 »
actually not false color.. true color taken in the visible by inducing the guards to fluoresce by stimulating them with ultraviolet light.
« Reply #4 on: November 25, 2020, 23:05:26 »
Touché. "false color' implies the color being falsified in the photo process. In any case, thanks for accurately recording the far out colors that the UV light revealed!
JohnMM
« Reply #5 on: November 26, 2020, 00:47:17 »
I like the pictures but I'm confused by the term 'resonance fluorescence'. I though that this describes the situation where excitation and emission energies are the same which is not the case here.
« Reply #6 on: November 26, 2020, 10:57:18 »
Very nice set of images side by side!Really impressive and creative approach ;)
« Reply #7 on: November 26, 2020, 12:42:37 »
Yes - you are quite correct John, e.g. the 254 nm UV resonance fluorescence radiation from the decay of the excited 6 3P1 state of Mercury to its 61S0 ground state  is a very good example of resonance fluorescence.  (Studied this one for my doctorate - a very long time ago I hasten to add!   :( )
