Author Topic: Pre-Ai lenses on the FTZ adaptor  (Read 1934 times)
John Harkus
« on: November 13, 2020, 19:28:35 »
So, the official instructions for the FTZ adaptor say that non-Ai (their words) lenses cannot be used.
I can't see any reason as to why this would be the case, as the FTZ lacks any physical aperture communication - can anyone enlighten me?
Thanks
John
Re: Pre-Ai lenses on the FTZ adaptor
« Reply #1 on: November 13, 2020, 20:00:42 »
I really don´t know why. I´m using the pre-ai (non Ai) 55mm 3.5 macro in the ftz with no problem at all
« Reply #2 on: November 13, 2020, 20:53:23 »
The rear flange on the lens aperture ring might stick or bind to the FTZ. Nothing a Dremel cannot cure ....
MILLIREHM
  • Vienna, Austria
« Reply #3 on: November 13, 2020, 22:10:40 »
My (non dremeled) Nikkor-H auto 50 mm f/2 does not fit although it was brute-force Ai-D
Wolfgang Rehm
« Reply #4 on: November 14, 2020, 10:56:45 »
most lenses would fit except for the really early ones with the extended aperture ring :o :o :o
John Harkus
« Reply #5 on: November 14, 2020, 16:49:03 »
Thanks all, just tried a pre-Ai 50mm, fitted easily and worked fine, as usual Nikon appear to be very conservative in their warnings
mxbianco
« Reply #6 on: November 15, 2020, 09:07:48 »
Better safe than sorry! I once clicked a vintage pre-AI 2.8cm onto my D300, and it was then really hard to click it off. Now that lens has a red label NON-DIGITAL as a reminder not to do it again!
After that bad trip, if I want to test a vintage lens, I rotate veeery slowly and if there's any doubt or increasing resistance, I don't go any further...
Ciao from Massimo
John Harkus
« Reply #7 on: November 15, 2020, 19:02:14 »
Ciao from Massimo
That's sensible advice Massimo, cheers
« Reply #8 on: November 15, 2020, 19:17:45 »
Alternatively, a clear indication the use of a Dremel is called for !!!
The advice not to continue mounting a lens if unexpected resistance is encountered is very sound, by the way.
