Author Topic: Finally got the 19mm PC-Nikkor to work the GFX  (Read 3020 times)
« on: October 18, 2020, 22:40:37 »
FujiFilm GFX 50R ,Nikon PC NIKKOR 19mm f/4E ED
1/80s f/8 iso50 at 19mm
1/60s f/8 iso50 at 19mm
Re: Finally got the 19mm PC-Nikkor to work the GFX
« Reply #1 on: October 18, 2020, 22:55:12 »
How  ;)  would help with a hint.
Thx
« Reply #2 on: October 18, 2020, 23:12:04 »
Quick fix actually. I used the Metabones Lens Adapter for Nikon F-Mount, G-Type Lens to FUJIFILM G-Mount GFX Camera, which does not support the E-type Nikkor lens. So I had to fix the aperture at f/8 by attaching to my D850 with the cap on, in aperture priority set to f/8 depressed the shutter and removed the lens before the shutter closed. This could have been any f-stop.
since I primary use this lens at f/8 it was no problem for me.
« Reply #3 on: October 18, 2020, 23:18:46 »
Ok. Great it worked out!
« Reply #4 on: October 18, 2020, 23:45:35 »
the widest I can get with the Fujinon lens is 23mm, so having a lens this wide with an image circle that will cover the sensor makes quite a difference. (15mm if you apply the MF factor for this camera = .79).
Nasos Kosmas
  • Athens, Greece
« Reply #5 on: October 18, 2020, 23:54:01 »
Very nice Bob, 15 mm equivalent for this excellent lens!
« Reply #6 on: October 19, 2020, 03:12:45 »
Wonderful capture, Bob!  The second one looks more appropriate for the autumn color.
