Author Topic: The Rodenstock APO Gerogon 150mm f/9  (Read 2374 times)
« on: September 29, 2020, 02:40:02 »
Here is a photo taken with the Rodenstock APO Gerogon 150mm f/9 as mounted on a lens board with the Cambo Actus Mini-B with the Nikon Z7 as the back.
I am comparing it to the Rodenstock APO Ronar 150mm f/9, which is also a process lens. It is said that the Gerogon is a wide-field process lens and has more internal glass in it and should (perhaps) perform better than the Ronar.
At first glance, first shot, it looks like it does at that.
Petr sheepeck Jůza
Re: The Rodenstock APO Gerogon 150mm f/9
« Reply #1 on: September 29, 2020, 03:48:03 »
I find these photos from APO lenses amazing.
Gerhard2006
« Reply #2 on: October 03, 2020, 05:09:56 »
Well I’m glad I suggested it although I didn’t think that you would go out and buy one but glad you did, the outcome certainly looks good glad you’re enjoying it. Gerry
« Reply #3 on: October 03, 2020, 08:23:26 »
I appreciate the suggestion.
