Author Topic: New firmware for the Z cameras  (Read 3489 times)
Re: New firmware for the Z cameras
« Reply #1 on: July 21, 2020, 15:11:05 »
The firmware is loaded to the Nikon sites and can be installed now. There is an update 1.10 for the FTZ adapter as well that hasn't been announced to my knowledge.
Both camera and FTZ firmware updated without hiccups earlier today.
« Reply #2 on: July 21, 2020, 19:44:39 »
Updated here too, no problems.
« Reply #3 on: July 21, 2020, 20:09:13 »
Z6 and Z7 smoothly updated.
« Reply #4 on: July 21, 2020, 20:11:04 »
Ah, a separate downloand, the MAFTZ0110.bin file.
Updated the Firmware MA version from 1:00  to 1:10  for Z6 and Z7
« Reply #5 on: July 21, 2020, 20:15:42 »
How can you check the FTZ-firmware?
You need to download the fw update for the ftz adapter and load onto your memory card, attach the ftz adapter only and check the fw in the menu, that way you can update the ftz adapter.
https://downloadcenter.nikonimglib.com/en/download/fw/360.html
« Reply #6 on: July 21, 2020, 20:17:31 »
Already discovered and updated, Fons.  Thanks.
« Reply #7 on: July 22, 2020, 10:45:35 »
What new features & fixes do you get with these?
« Reply #8 on: July 22, 2020, 11:41:53 »
I presume that one needs to repeat this process for each FTZ adapter that one has - the camera just being the conduit or "middle man" as it were.
Eddie Draaisma
« Reply #9 on: July 22, 2020, 13:38:16 »
The FTZ adapter firmware needs only to be updated to 1.10 in case one wants to update the firmware of certain F-mount lenses, the 70-200/2.8FL being one of them. Which are the other ones?
« Reply #10 on: July 22, 2020, 14:27:32 »
Yes, repeat for every FTZ. In my case, all four of them :(
