Author Topic: MF Utrawide Zooms. How many are there?  (Read 6436 times)
Steven Paulsen
  • Cumpulsive Tinkerer
« on: July 04, 2020, 01:32:26 »
They don't have to be stellar, but are kind of few and far. (I'll try first.)
From the old Nikkormat days I have a Sigma 21-35. 36mp may be pushing too far on this one, but it isn't a slouch.
For S & G's I picked up a Samyang 18-28/4-4.5. It is a wobbly, somewhat loose zoom & focus ring, but stopped down I have gotten some great results.
Are there others worth adding? There has to be a few more.
The silly little Df opened a 30 some year window deluding that I'm 30 something again with a proud sack of glass. ;) I wish they had a screensaver that looks like pebbled vinyl with film holder to nix the rear display.
ianwatson
Re: MF Utrawide Zooms. How many are there?
« Reply #1 on: July 04, 2020, 19:28:15 »
I'm not sure if it counts as ultra wide but there is the Nikon 25-50mm f/4.
MILLIREHM
  • Vienna, Austria
« Reply #2 on: July 04, 2020, 23:28:52 »
I would say no. Super/Ultra wide starts at 20/maybe 21mm and shorter, 24mm and above is conventional wide angle
one could as well say (if one makes a difference between super and ultra wide, ultra should contain at least 15 mm or below)
Wolfgang Rehm
« Reply #3 on: July 05, 2020, 10:04:07 »
I think the ultrawide Nikkor zooms are all AF / AFS lenses. But you can focus them manually.
20 - 35 /2.8 or 17 - 35/2.8 could be a candidate?  Maybe a 17-35 that has the "squaking" problem you may get it cheap and use it as MF only?
Steven Paulsen
« Reply #4 on: July 05, 2020, 21:19:14 »
First, Thank You.
I was going to say anything that starts with a FL under 24mm.
I don't know how many attempts I've made long ago using "Whatever" book, learning 35mm photography with a 50mm. For some reason, I seem to hate 50's. A 35mm prime made everything more in perspective. I later acquired a 28, 24's and recently, an old 20mm.
I have the old 18-35/nikkor and a tokina 17-35, AF, but what I'm mired in at the moment, an all manual focus lens kit. A 16mp camera that is quite forgiving in noise reduction that is also fun with old, 30-40 year old primes, I don't necessitate a Df in needing a $2K prime.
If you take off the filter the DX 12-24 nikkor is quite usable @ 16mm & above but it's another confounded Af lens.
« Reply #5 on: July 06, 2020, 19:11:46 »
The 17-35/2.8 is easily manually focusable, and a copy with AF issues could make a good choice for a reasonably priced, good quality wide angle zoom.
« Reply #6 on: July 06, 2020, 19:12:46 »
The Nikkor 25-50 is as far I can see in a Nikkor system handbook the most wide MF zoom Nikon has made.
But the AF 20-35/2.8D is almost a MF lens if you switch from A to M on the lens. I read that this lens has a very good MF feel. Lens has the "screwdriver AF".....so it will not make the lens much bigger than if it was a pure MF lens. Then you still have the advantage from the chip and contacts.
But it is also the "look" of a pure MF lens and the feel of old focus helicoids you like?
Steven Paulsen
« Reply #7 on: July 07, 2020, 19:51:15 »
Pluton. You are welcome to join my cheapness club, for free. (DOA, 17-35.)
What I'm after is the feel of a long throw chrome/black barrel lenses. Most af lenses have a short amount of adjustment, (throw,) and its generally a pain or compromise to use manually.
It would be a really nice feature......on Af lenses stopped down, (say F8) for the camera to use hyperfocal distance in setting focus. I love those little tick lines on older wider glass.
« Reply #8 on: July 07, 2020, 20:13:02 »
I like the idea of The Cheapness Club!
Agree...A lens well-designed for manual focus, like the old MF Nikkors, is preferred to the compromised manual focus action on the AF lenses. What I'm thinking is that all the really good wide-angle zooms were produced after the start of the auto-focus era. Therefore, there are no native manual-focus wide zooms.
« Reply #9 on: July 07, 2020, 20:18:34 »
The Nikkor 20-35 has a marking for 20mm and a marking for 35mm. I guess it could be for F8 (but have not investigated it).
But it does not have those curved colored lines the old push-pull zooms had for each aperture setting.
The 20-35 is probably the closets you get if it has to be a ultra-wide Nikkor zoom.
Old MF "other 3. party brand" zoom lenses probably has a poor performance compared to a Nikkor! :-)
Maybe Leica has something where you can use an adapter.
CS
« Reply #10 on: July 07, 2020, 21:11:13 »
Posting error, sorry.
Carl
« Reply #11 on: July 07, 2020, 21:27:31 »
There is a bit more information about 20-35 here:
https://www.mir.com.my/rb/photography/companies/nikon/nikkoresources/AFNikkor/AFNikkor2035mmf28D/index.htm
…..and development of wide angle zooms in general. Also link to Nikkor 25-50.
« Reply #12 on: July 07, 2020, 22:41:42 »
Those marks are the infinity points for infrared shooting, nothing to do with depth-of-field.
« Reply #13 on: July 07, 2020, 23:13:37 »
Ok....then there is only the "paper scale" solution provided by Nikon...…
The infinity focus at 20mm is quite far away from "visible light" infinity…..so not so well corrected I guess.
« Reply #14 on: July 08, 2020, 11:55:44 »
Guessing depth of field, ie hyper-focal distance in setting focus for a digital camera is hit and miss, definitely not recommended, not even for ultra wide lenses. A scale on the lens barrel will not change that.
20-35mm AFD f/2.8 is a very nice lens, the MF fell is very nice and smooth and it's very compact, almost no geometrical distortion on top!
