Author Topic: PC 85mm f2.8 axis shift rotate issue .  (Read 1278 times)
CardBoardBoxProcessor
« on: June 30, 2020, 05:11:08 »
Small problem.
The two flat cables that connect the front to back move about into the lens area and stopped it from shifting which led to them beginning unplugged.
I can probably plug them back in but won't they just be in the way again?
Obviously it works without apperature data just fine but I'd like to resolve this best I can
Steven Paulsen
  • Cumpulsive Tinkerer
Re: PC 85mm f2.8 axis shift rotate issue .
« Reply #1 on: July 04, 2020, 01:37:13 »
The Boss will answer that one when he sees it. (It's one of my favorite lenses.)
Andrew
« Reply #2 on: July 04, 2020, 11:05:32 »
Not good enough...
Cables for rotation position are different.
Erick with Bjorn was trying to do in Fryburg, no cigar. Price at Nikon Dortmund is quit high.
I did give-up.
And
Andrew Iwanowski
« Reply #3 on: July 04, 2020, 18:36:30 »
Yes, longer cable is needed for a good solution  ;)
You can get it from Nikon.
« Reply #4 on: July 05, 2020, 01:44:54 »
Hmm. I guess I'll get a quote and see if it is worth it. I ended up just gaffers taping them down inside the body. Thanks
Thankfully the lens works fine. Actually be finally used it today for the first time. Amazingly sharp and versatile.
