"NG 10 Years" competition: RESULTS !!!https://nikongear.net/revival/index.php?topic=11252.0Current status: 82/150 supporters
So to sum up.....there was no Haze issue?The lens is optical perfect but electronics does not work and to overcome this you have set camera to treat the lens as a lens without chip.....so just as a normal AIS lens?If the electronics made to much troubles and made the camera show "ERR" a way to avoid this was to completely cut the connection to chip. Then lens should work as a normal AIS lens without changing anything in the menus? …...you should just not lock the aperture ring to f22?But if you can use the lens now as a G-lens with aperture ring locked and manuel focus this is of course the best solution but that requires that some part of the electronics work?I am a bit confused of what the fault was on the lens?
Hey Matt, when looking through the (bad) lens, did you see the glue?Mine looks crystal clear.I'll take some test picture soon after my work, but it seems like you guys will not see the coffee mug.Thanks,Zang
I presume it was the glue I saw. It was quite cloudy, and immediately obvious that there was a problem...
Nothing is wrong, but 1 more image to infinity, wide open, and the same, at 5.6. LZ
It is a good copy, of what it really is, especially for the money you paid. If possible, avoid using it wide open, f4.0, at least. Yea, there are some optical imperfections, but anything looks worse than any old lens of its kind! LZ
